Pete49
Distinguished
as the title says. My '75 450 SEL drivers side window regulator is cactus. The motor is fine but I guess at nearly 50years old its been a good unit. I reckon by the sound of the gears not meshing that the alloy frame is bent. I had removed it a couple years back to replace the motor and while it was out straightened it and I lubed everything with a good dry lube and its been ok but now need to buy a new (used) unit so can anyone give me a lead to one? Is one from a 280se a fit so maybe another option?
I'll also post this on the ozbenz site to widen the search.
cheers
Pete
cheers
Pete
