560 Throttle Body onto 6.9
More threads by john erbe
john erbe
vallejo, california
Having read some past posts I believe some of you have done this and could answer some questions as I have started the project having just pulled the TB from a wrecker 560. Aware that I've got to machine a larger bore on the 6.9 intake manifold but, what about the top end, can the port on the underside of the 6.9's air/fuel manifold be enlarged or do I need to bring over the whole 560 set-up? I note that the latter's belly is plastic as opposed to metal on the 6.9.
Isnt it a flexible connection? I've heard u need an aftermarket hose... Any pix of the parts involved?
J
john erbe
vallejo, california
It's a flexible connection on the 560 but I haven't taken opened up the 6.9 yet. Should it also be flexible, can it accommodate the bigger bore is the question. Hoping someone would know as that would make things much easier.
Hi John yes it is a flexible hose between the 2. Fuel distributor has just under 90mm opening underneath so not a problem . You can use a silicon turbo hose as the connector. like when I fitted 92mm LS throttle body.
J
john erbe
vallejo, california
Oversise and others, I've attempted to attach photo of the underside of the air intake/fuel distributor of the 560. If I've failed, check my recent post of the same topic on the M-100 website, where the photo shows. Now, some questions: Referring to the port with the flex fitting as you call it, shown in the photo, which comes down on the TB, does that same port on the corresponding manifold of the 6.9 have sufficient aperture to accommodate the larger bore of the 560 TB? In brief, what parts in addition to the electrical connector(s) do I need to bring over from the 560? Also, are the bolt patterns of the TBs the same, and lastly, will the single snorkel air filter of the 6.9 meet the increased demand? Thanks.
All good stock Euro with 8.8 comp made 230.1 hp at rear wheels . I made 255.6 hp with 2.5 inch duel exhaust and x pipe and custom ceramic coated extractors/Headers to you John. Made around 20hp more with 92mm LS throttle but due to shaft being 25mm to high car was un driveable lift throttle it closed plate. I have since has 3 85mm throttle bodies made they are cad scans off factory 65mm throttle body . They will go on and be dynode once car is out off paint shop and Franken CIS will be fitted at the same time. Will move battery to fit 560 air cleaner have 560SL air horn to fit replaces smaller air horn so they are both same size.
J
john erbe
vallejo, california
Looks good Motec. Unfortunately here in California we've got to deal with state emission tests so your dual set-up mod would be considered "tampering" and thusly taboo.
c107 Carobu Engineering - 560 Dyno Testing Mercedes W126 30
Patrick_R 560 auxilliary fan Mercedes W126 4
Oversize WTB S2 126 560 Hydro Struts Gumtree/eBay/Facebook Listings 5
motec 6.9 Another 560 for Mark Gumtree/eBay/Facebook Listings 6
Oversize Carburettor conversion on a 560 Mechanicals 4
Styria 560 AMG SEC Coupe Road Tests 1
Des Amg 560 Talking Torque 1
J 560 SEL Interior (complete) for sale Gumtree/eBay/Facebook Listings 5
Oversize Custom throttle bodies Mechanicals 7
Oversize 6.9 vs 6.3 throttle bodies Mechanicals 2
Oversize MB Throttle linkages Mechanicals 0
Styria Blip that throttle Mechanicals 5
SELfor50 Throttle linkage adjustments Mechanicals 2
S body dress strip Mercedes R/C107 2
Oversize Late model body kits Gumtree/eBay/Facebook Listings 1
motec 6.9 ugly w116 body kit Exteriors and Body Repairs 19
Styria Astral Silver 6.9 body preparation Exteriors and Body Repairs 23
M The Chronicles Of Mercules - Body Repairs Exteriors and Body Repairs 62
