My W140 500SEL ('92) is an early version with the basic 4 speed torque converter tranny. It seems similar to 70's and 80's benz transmissions in design.
It is not slipping at all, in fact the gear changes are a little hard if anything. Recently is has developed a tendency to 'shudder' as it changes gear. This is most noticeable on the 1st to 2nd change, and is worse under full throttle conditions.
I've used the word shudder, but its quite tough to describe, but that's the best term I can find. The shudder is very brief - perhaps half a second. There is no obvious slack in the diff, sideshafts or driveline.
I FINALLY got underneath the car to have a look this evening. The front flex disk is in a fairly advanced stage of developing the Don King hairstyle......
The rear flex disk looks OK.
I'm unsure how to judge the state of the centre bearing - visually it looks OK. I can deflect the shaft sideways with modest pressure applied to it near the bearing. Does this sound reasonable? Any tips for diagnosing centre bearings?
I think I also have an engine mount problem. Recently its been feeling like the engine bounces around undamped when going over sharp corrugations etc. I had assumed there were mounts and separate dampers as on the 70's benzes, but this appears not to be the case. The engine mounts appear to also perform the damping function.
