seeking replacement front grill for w116 450SEL 1979
More threads by Goldacre
G
Goldacre
Due to an unfortunate incident i am in the market for a replacement front grill for my car. :(
My panel beater has indicated that he has not been able to locate one in good condition, particularly the aluminum strips across the front of the grill, either missing or bent. :eek:
If anyone knows a location of a good unit or has one they could spare for a 'good for me good for you price' please PM me. I am in Western Australia and postage is no problem. :)
Much appreciated
JG
You can buy the strips new still from MB. The 6 horizontal ones are fairly inexpensive, the vertical one is quite expensive.
I.
I.
It's the one that goes first... :eek:
I know of a guy who has 3; I may replace mine sometime soon by upgrading to one of his. The grille on my car is quite OK. I has no damage, just that the plating is showing its age somewhat. It came off a 280 SE, the item that came with my car 8 years ago car was damaged. The rubber seal between the bonnet itself and the grille is 30 years old and is very easily damaged when pulling the grille from the bonnet. You could make a new one from sheet rubber stock from Clark rubber, if you did not want to buy a new one from MB, If it became damaged beyond repair, or you could be lucky enough to get an intact one off a w116 wreck. Also Styria may be able to help. You could have my grille for nix. The actual replacement job is very simple.
That's a generous offer - from what I recall, SEL 69L's grille is in pretty good condition. Certainly the offer could be further investigated. Also, as B13 points out, the trim bars are still procurable from Mercedes Benz. Regards Styria
The W126 chrome strips were (it's a while since I checked) much cheaper and more readily available from the dealers than the W116 strips and can be trimmed to fit.
Next visit to Pick 'n Payless junkyard, grab hold of some of those little plastic clips that hold the grille trim bars in. Like anything else on a 116, these clips are of the order of 30 years old and a few spares would not be unappreciated especially if you break a few, or some are missing, which can be expected.
G
Goldacre
Thanks everyone for your helpful advice, following on from what B13 and Styria have suggested i have ordered the replacement front trim at a scary cost.
The bloke sourcing a replacement grill called me this morning and says he has found a real gem of a grill but with ALL the front trim missing, i guess someone got to pick 'n Payless before me :mad:
Thank you SEL_69 for your kind offer, this is what makes the forum so helpful when a person hits grief with their car, the forum is a happy family to come home to :)
I guess the clips that hold them in are extra with the new trim?
J
Interesting that people mention the clips. I purchsed a perfect grille from Pick-a-part for $44 and decided that since it was going on the race car it might look nicer with the plastic insert painted black.
Sliding out the trims showed the clips were all OK, so I just painted the insert black, clips and all. Gave it a couple of days to dry and then carefully re-installed the trims - looks a million dollars:
So I don't know why these clips are perceived as being weak or non-reusable.
I.
G
Goldacre
Thanks for that Lukas, just saved myself a pretty penny :)
I shop at Autohausaz often and had no idea these were available there, just getting the vertical one now, tops.
Painting the grill black looks pretty AMGish, don't think my car would qualify for that treatment, she looks pretty austere :rolleyes:
Thanks folks, the money saved has been used to get a few other parts to dress the old girl up, looking forward to the next Perth get together which is due around now.
J
Oversize Replacement Wheels & Cleaning Exteriors and Body Repairs 3
Styria 6.9 Carpet Replacement Interiors 1
Oversize Suggestions for a daily replacement Talking Torque 20
c107 Monovalve replacement Mercedes W126 0
4 450SEL Hood Pad replacement Exteriors and Body Repairs 23
L Clock Replacement Mechanicals 5
WGB RH Sway bar chassis bush replacement in RHD 6.9 Technical Information 0
abl567 6.3 Camshaft replacement Mercedes W108 and W109 0
Styria Replacement of four doors - 6.9 Technical Information 25
J 6.9 Air cells check & replacement Mechanicals 8
BenzLover Engine radiator replacement Mechanicals 3
A Aircond compressor replacement Mercedes W116 32
WGB Rear trailing arm bushes - replacement in-situ possible? Mechanicals 2
WGB In-situ 6.9 rear strut ball joint replacement Mechanicals 4
abl567 Injection pump replacement. Part 2 Talking Torque 3
B Steering Box replacement Mechanicals 8
WGB 6.9 timing chain replacement Mechanicals 8
s class 6.9 chain tensioner replacement vs rebuilding Mechanicals 11
Oversize Found under the front seat... Articles 3
Michel WANTED: Front Bumper Bar For CLK Gumtree/eBay/Facebook Listings 2
6.9forever SL/SLC front bumper rubber kit Exteriors and Body Repairs 5
motec 6.9 Febi front accululators Gumtree/eBay/Facebook Listings 23
motec 6.9 New front struts German ebay Gumtree/eBay/Facebook Listings 18
abl567 Front Strut Ball Joints Mercedes W116 4
R AMG front Spoiler Exteriors and Body Repairs 14
M '72 107 Front Turn Signals Exteriors and Body Repairs 1
Styria Leaking front screen Exteriors and Body Repairs 10
300SDude W116 Front Ashtray For Sale Gumtree/eBay/Facebook Listings 0
Styria 116 Front Axle - Drawing Technical Information 0
T Relay on the front panel near headlight Mechanicals 1
