looking to buy 450SE
New member cjgd is looking for advice regarding the possible purchase of one of the above. He is located in Canada, it's believed to have travelled about 200ks. and is selling for $2500 Canadian. He believes it to be rustfree but is looking for advice as to what to look for prior to purchase.
I am advising as follows, but am looking for input from others as well. First of all, he needs to establish if it is a 450 or perhaps even a 6.9. This is best ascertained by checking chassis numbers on the firewall. 116 036 for 6.9, 116 033 for 450SEL and 116 032 for 450SE. With the bonnet open, also look for the location of Alternator, type of Hydraulic Oil Reservioir, Oil Filler cover to replenish with oil and also check if rocker cover(s) have an oil filler plug. So, that's a start for identification. Refer to a couple of pictures attached.
Next check exterior of body for condition of paintwork and rust, have a good look at the front and rear screen rubber seals. Check operation of sunroof, if fitted and examine channels when open.
Interior wise, look for wear and tear on seats, particularly for collapsed rear seat (if leather), check condition of carpets and also the area under carpets for moisture or ingress of water, particularly in the sound proofing foam that is glued to the front floors. As with any used car of that vintage, you need to be prepared having to spend some money on mechanicals etc., but if possible examine invoices and service records to indicate thether or not the car has been well maintained and looked after. That's for starters, others may have additional suggestions. Regards Styria
cjgd
Canada
Thanks Styria, I'm new to the group and trying to figure out a few things, before purchasing a 450se I found.
Is their anything specific a mechanic should look over in a basic certification?
Assuming it's in fair condition, what price range do you guys think is appropriate for that kind of car as a 6.9 or as a 4.5. Is $2500cdn too much or reasonable given the work and maintenance involved.
I have a feeling that it's leaning to being well maintained on the mechanicals but needs work on the interior.
I saw a post about adding a few gauges to the cars such as a low water alarm. Is there anything that should be upgraded right from the start with these cars?
Thanks
If the car is an SE, then it's very unlikely to be a 6.9 as Mercedes did not make a short wheelbase 6.9 and very few Mercedes enthusiasts would go to the trouble of doing an engine swap from an SEL into a SE.
You'd be suprised.. :rolleyes:
I'm pretty sure somewhere, someone has a 450 SE 6.9
Hi cjgd, further to your enquiry and likelihood of purchasing the 450 SE (we assume). Have you checked the chassis number at this stage to establish the model you're dealing with ?
It's probably fair to state that, for the quoted purchase price, you can only expect a car in 'reasonable ' condition. If you're buying it for transport needs, obviously mechanics and their condition need to take preference over a car with an excellent interior although it'd be very nice if you were to get it.
If you're not familiar with Mercedes Benzes, it is of importance that you engage the services of a competent Mercedes Mechanic who will be able to give the car a thorough check. That, indeed, would be my initial recommendation. If you can get a clean bill for that, the rest will fall into place, depending on your wishes and desires at future times - as far as the car and its condition is concerned. Regards Styria
cjgd
Canada
I have found a mechanic that could do the work, recommended by a friend who says hes very reasonable, mercedes specialist. I'm going to see 2 450 6.9's SE's over the weekend, one a convertable. And a 4 door possibly next week.
How far does 6K go to bring the mechanicals to top condition in a car like this assuming the engine is good? Is it safe to say changing the brakes, alternator, battery, tires, fluids, lights, similar in cost to other older vehicles? Or can you have a dilema where you can't get/find the part you need?
And does anyone have any have any links to mods or 'upgrades' that could e made to a 6.9? Mainly for more HP.
And lastly, how many km does a 6.9 engine typically get up to before a rebuild?
Thanks for all the info everyone, I'm learning alot.
Check very carefully for rust, as rust is the real killer with these cars. Mechanical parts are in reasonable supply.
If you are in Canada check parts prices with Randy Steele in the USA, Randy is way cheaper than buying most W116 parts through a Mercedes dealership - W116's are probably too old for a dealership to be interested.
Hi cjgd, spending $6k. on mechanical repairs would be plenty to return 90% of 116's to pretty good mechanical condition. It just depends on how good, or how bad, the car is that you are wanting to purchase. 6.9 engines are long lasting, especially block and heads, and most ancillaries such as alternator etc. are not too badl;y priced. It all depends where you have the work done etc.
In your situation, I tend to think a proper mechanical inspection is a must. Regards Styria
cjgd
Canada
I agree, I will have it completely inspected before purchase.
Does anyone have the contact information of Randy Steel>?
There is a 450SE in Canberra with a 6.9 engine, but this was not a genuine factory vehicle. It had the 6.9 motor transplanted.
A true 450SEL 6.9 had not just a long wheelbase and big motor. They also had the hydraulic suspension (no springs and shock absorbers).
SO if you are looking at a car that has a 6.9 motor, you should be able at a glance to tell if it is a true example, by virtue or the length of the car and lack of springs.
A standard 450SEL has the longer wheelbase, larger rear door glass and an oil / air rear suspension.
For a quick check on the probability of W116 being a 6.9, the front suspension should have the oil / air struts plus black cam covers.
BenzLover Looking to buy again! Gumtree/eBay/Facebook Listings 0
Michel Looking for a star emblem Gumtree/eBay/Facebook Listings 2
c107 nice looking Classic Bentleys for sale Gumtree/eBay/Facebook Listings 4
260ebenz Battleship looking it's best Mercedes W126 94
S Looking at buying a 6.9 SEL Mercedes W116 4
260ebenz Fine looking 300D for sale Gumtree/eBay/Facebook Listings 8
260ebenz Two fine looking Battleships for sale Gumtree/eBay/Facebook Listings 0
260ebenz Impressive looking 1970 280SE 3.5 W111 for sale Gumtree/eBay/Facebook Listings 3
Michel A different looking W116 Gumtree/eBay/Facebook Listings 4
F Looking for advice - new carpets Interiors 9
H looking for parts in tassie if anyone has any Gumtree/eBay/Facebook Listings 8
Des Nice looking W116 Gumtree/eBay/Facebook Listings 10
Des Nice looking 116 Mercedes W116 11
Des Nice looking SL Mercedes R/C107 1
A Wanted to Buy: 350 or 450SLC Feb/March 2022 Mercedes R/C107 13
BenzBoy Want to buy a 6.9? Mercedes W116 1
motec 6.9 Will never buy a W107 Mercedes R/C107 20
BenzBoy Time to buy VW shares? Talking Torque 20
motec 6.9 Vic Forestry buy G Wagon Articles 0
Styria Why buy a Mercedes Technical Information 52
260ebenz Would you buy a car from Larry? Talking Torque 1
CraigS 6.9 head gasket - part No / where to buy Mechanicals 41
BenzBoy Would you buy a 1997 C200? Talking Torque 7
M 14" bundts refinish or buy new? Exteriors and Body Repairs 4
SELfor50 If it was in Australia, i'd "buy it now"! Gumtree/eBay/Facebook Listings 5
BenzBoy Why did you buy a W116? Mercedes W116 13
L Dismantling a 450SE Mercedes W116 22
