560SEL Trans & Diff
Would you have a drivers side front window regulator from one of the W126's looking for a home? and a W116 drivers front door stay? :)
I would say yes but I'll have to check!
Anyone know if these items are the same on W116 and W126? Or are they a better design that could be adapted? Would 560 cam followers and tappet compensators be interchangeable with ones on the 6.9?
I know the 4.5 litre ones are the same. So its possible.
I do know the solid lifters from116 are used With AMG 50.1 CAMS IN M117 .
No idea how to use the EPC but I guess there's a first for everything! :eek:
Bye!!!:rolleyes:
Unfortunately it was removed by someone else before I got it!
In the end, Mark, did you decide to save many components ? I see the engine and gearbox were removed, any other items, such as gearbox, diff., FRONT brakes (Motec wanted them) etc. etc. Was it all worth it, would you do it again ? Regards Styria
I saved the whole driveline, brakes, sunroof, bonnet, seats and brackets. Plus various other bits and pieces that I thought should be retained.
Time will tell if it was worth it and it was certainly time consuming. But it did give me a great insight into the cars and allowed me to compare W116 and W126 from the inside. Certainly far more plastic on the W126 and other items that aren't quite as sturdy as the W116.
Would I do it again? Yes, that's the plan as I have lots more to process.... Hopefully not to the same level since time ticks by so quickly and I don't want to spend all mine stripping cars! One day I might get to DRIVE one on a weekend cruise!
motec 6.9 RM AUCTIONS 560sel 6.0 Mercedes W126 0
Oversize Full House 560SEL Mercedes W126 1
c107 C107's 560SEL Mercedes W126 72
Oversize Midnight Express RUF 560SEL Mercedes W126 15
Oversize 560SEL with a twist... Gumtree/eBay/Facebook Listings 15
Patrick_R Patrick”s 560SEL Mercedes W126 38
Oversize 560SEL Barn find in Italy Mercedes W126 13
Styria 560SEL - For Sale Mercedes W126 2
260ebenz 560SEL for sale Gumtree/eBay/Facebook Listings 33
Oversize White 560SEL Wreck Mercedes W126 33
Oversize Champagne 560SEL Mercedes W126 37
Styria 560sel & 500sel Road Tests 3
Styria 1991 Mercedes 560SEL Websites and Links 1
Oversize 420SEL vs 560SEL Mercedes W126 21
Styria 1986 Mercedes 560SEL Road Tests 4
260ebenz LHD 560SEL for sale Gumtree/eBay/Facebook Listings 4
Oversize Euro 560SEL for sale? Gumtree/eBay/Facebook Listings 2
S Auto Trans demise Articles 22
BenzBoy Auto trans fluid change. Talking Torque 10
s class 350 trans keeps pushing fluid out the overflow Technical Information 6
s class help with 722.002 trans question re K2 Technical Information 3
s class 350SE trans failure Mechanicals 11
S For budding Automatic Trans mechanics Mechanicals 13
Oversize Weight of a 6.9 engine & trans Mechanicals 26
A 450sl diff ratio Mechanicals 13
J What ratio diff do most 450 116's have Mercedes W116 13
smueller99au W107 Diff Interchangeable with which model? Mechanicals 3
B Can anyone identify this diff? Mercedes R/C107 7
abl567 Diff dramas Mercedes W108 and W109 29
B 350SL diff into 450SE - speedo correction Mechanicals 5
