450SEL Air cond
More threads by AAB
AAB
Toorak Vic
The air conditioner in my beloved 450 has decided to leak water onto the floor in front of MrsAAB.
Any clues as to where I start to look,....as I am only clued up on replacing A/C compressors, & I would appreciate some guidance as to how to rectify this problem.
Alex
Sorry for the bad news, but it is a reasonable job.
It will be the condensate drains at the base of the HVAC unit. They are accessable with the centre console removed and are probably blocked. Also there is a remote chance that the HVAC unit's housing is cracked.
KenM
Brisbane, Aus
I've got the exact same thing with the '75 450 SE that I have recently purchased. Fortunately for me it is only a recent occurrence and there is no rust in the floor pans at all. I have bought the heating and a/c manual and have been looking through it, as TJ says it seems as if just getting to the drain will require removal of the console. One thing I did find out is that there were an early and late version of the drainage system, the early only had one drain point and on the later they fitted a second, obviously to cope with the amounts of water. I haven't started to attack mine yet, except to get the floor mats and sound deadening up, which is critical because that stuff holds water like you wouldn't believe, it took a week of mine hanging in full sunlight before they dried and by then they had shrunk to about 1/3 of their thickness when I pulled them out, massive sponges.
Cheers,
Ken
It is likely only to be blocked drains and they should be visible from under the car as rubber tubed coming out oif teh transmission tunnel around the bellhousing end of the transmission.
Some judicious probing with string trimmer plastic or such like should liberate a faceful of smelly water.
A
AAB
Toorak Vic
Many thanks for the prompt replies.
Tim, by the " centre console " you do not mean the whole hump do you ( I hope !!!) but the bit with the knobs on ?
Will get onto the job ASAP, but it is a bit warm outside, so will probably attack it over the weekend.
Alex
Yep, I mean the whole thing.
I would try WGB's trick first though, but there isn't much space under the trans tunnel without a hoist.
By far the quickest way, if you can get the car off the ground, is to locate the two drain pipes either side of the transmission tunnel.
A small plastic tube can then be inserted and in most cases will clear the blockage.
If you are lucky, you could try lifting the sides of the ccentre console near the firewall (this will be the flexible carpeted section. You may be able to see the rubber hose pipe that runs down from the a/c duct into the tunnel - if so pull the hose out and attempt to clear the blockage and reinsert it.
6.9forever
Sunshine Coast
Have had the same thing with my 6.9.
There are three possible causes in my experience. Investigate them in this order:
1. The rubber drain hoses are most certainly accessible without removing the console if of the type I have on my 78 model W116. You do have to unscrew the trims under the glove box and under the steering column tho' and insert yourself head first into the footwells equipped with a good torch. Locate the rubber tubes, pull them off and clear them. Re-attach. (I suppose you could also access them from under the car as WGB rightly says but I went in through the car's interior instead, as described).
2. Also check for excessive refrigeration which leads to condensation in humid weather that then drips into the footwell. To avoid, do not wind air-cond dial past the re-circulation "notch" mark on the blue-printed dial.
3. The plastic moulding that the drain tubes attach to is relatively old, brittle type black plastic so a crack is conceivable, requiring repair or replacement, tho' unlikely.
6.9forever
Sunshine Coast
...as a follow-up, wet W116 floor pan insulation is not worth keeping. It is sticky, smelly, mucky stuff and the floor will rust. The first point is under the accelerator pedal and also a lower collection point in the aft foot wells. I chucked mine out and replaced (courtesy House of Styria) with Dynamat and the smell is forever gone.
A
AAB
Toorak Vic
Did a check on the two drain hoses,..definitely not blocked up,.also poked a wire into the plastic pipes & they were clean also.
I was able to access the 2 hoses, (each only about 100 mm long) by carefully pulling the flexible console sides clear.
Not much drama except the driver's side, where you need to be a bit of a contortionist.
Alex
6.9forever Catalan 450SEL restoration that must be seen to believe! Mechanicals 1
Oversize Differences between a 450SEL & 6.9 Mercedes W116 1
6.9forever Icon Gold 450SEL in good condition Gumtree/eBay/Facebook Listings 3
4 1975 450SEL for sale $1000 Mercedes W116 7
260ebenz 450SEL 6.9 for sale Gumtree/eBay/Facebook Listings 32
S What to do with a 450SEL Mercedes W116 3
Styria 1978 Mercedes 450SEL 6.9 Gumtree/eBay/Facebook Listings 9
4 Petrol smell in cabin of 450SEL 4.5 L Mercedes W116 7
4 1975 450SEL for Sale in Sydney Gumtree/eBay/Facebook Listings 6
260ebenz 450SEL 6.9 drive Mercedes W116 6
O A couple of 450SEL qns from a new guy Mercedes W116 15
Oversize Two Tone 450SEL Gumtree/eBay/Facebook Listings 10
motec 6.9 Black Euro 450SEL Gumtree/eBay/Facebook Listings 6
260ebenz 1974 450SEL 64,000 miles Mercedes W116 7
Styria $a100k - 450sel 6.9 Websites and Links 1
B 450SEL 6.9 for sale in South Australia Gumtree/eBay/Facebook Listings 20
260ebenz 450SEL for sale Mercedes W116 1
Michel 450SEL For Sale (2nd Owner) Gumtree/eBay/Facebook Listings 30
260ebenz Michel's 450SEL Mercedes W116 5
260ebenz 450SEL for sale Mercedes W116 5
260ebenz 450SEL 4.5 for sale Gumtree/eBay/Facebook Listings 5
Styria Mercedes 450SEL 6.9 Road Tests 0
motec 6.9 2xNice 450SEL on Carpoint Gumtree/eBay/Facebook Listings 10
L Chopped 450SEL Mercedes W116 4
motec 6.9 Nice 450sel for Tony Gumtree/eBay/Facebook Listings 2
WGB 450SEL - wakening after long sleep Exteriors and Body Repairs 20
motec 6.9 Nice 450sel Gumtree/eBay/Facebook Listings 2
Oversize 450SEL for sale Gumtree/eBay/Facebook Listings 9
Oversize 450SEL sold for $1500 Gumtree/eBay/Facebook Listings 0
Tony66_au 450SEL 6.9 for me? No. Mercedes W116 7
300SDude Craigslist 1975 Mercedes W116 450SEL - $3995 Gumtree/eBay/Facebook Listings 6
300SDude '76 450sel $800 Gumtree/eBay/Facebook Listings 0
