Replacement of Air Con hose
Lucky for me, I have the special tool that's required to crimp the air conditioning hoses. In the end, this job was quite simple, especially as the radiator been removed, as well as battery tray etc. etc.
Picture shows the new hose in place, together with suitable sheathing and attached to the metail Air Con pipe. It was then to ensure that routing the hose prevented any sharp objects from puncturing the hose again. The next picture shows the new hose offered up to the connection on the receiver/dryer with the old fitting in place loosely to determine length of new hose.
Whilst in this area, some painting and detailing work....
........as well as the twin washer pumps, having been cleaned and serviced.
Regards Styria
J Euro Headlamp Bushing DIY Replacement Technical Information 0
Styria 6.9 Carpet Replacement Interiors 1
Oversize Suggestions for a daily replacement Talking Torque 20
c107 Monovalve replacement Mercedes W126 0
L Clock Replacement Mechanicals 5
WGB RH Sway bar chassis bush replacement in RHD 6.9 Technical Information 0
abl567 6.3 Camshaft replacement Mercedes W108 and W109 0
Styria Replacement of four doors - 6.9 Technical Information 25
BenzLover Engine radiator replacement Mechanicals 3
A Aircond compressor replacement Mercedes W116 32
WGB Rear trailing arm bushes - replacement in-situ possible? Mechanicals 2
WGB In-situ 6.9 rear strut ball joint replacement Mechanicals 4
abl567 Injection pump replacement. Part 2 Mercedes W108 and W109 3
S Air Bags Articles 5
S Air Con mystery Articles 24
A Air con drain Mechanicals 3
Oversize Restrictive Air Filter Assemblies Mechanicals 50
