Mercedes V8 Inlet Manifolds
Yet another redesign for packaging which makes it more adaptable, simpler and thus quicker & cheaper to build. It might even work better… A quick redraw & it’s back to the fabricator. Hoping this will all bring some major progress to the project!
Taken from Bills thread about the Mampe 450SLC twin throttle:
So doing some very basic math using % hp vs capacity the following theoretical increases could apply if you made the same vintage mods to different engines:
370hp from 450cc
459hp 560
566hp 690!
If you do the same based on the AMG 500SEC (ITB):
454hp 500cc
510hp 560
628hp 690!
Note some people are sceptical those figures are accurate & actually inflated. However the drivers did report the cars chewed up racing slicks and you can’t do that with low power!
If you base it on % hp increase Std vs competition (73% increase):
519hp 300hp 560
495hp 6.9 Euro
431hp 6.9 US
460hp 6.9 AUS
Basing it on the Red Pig:
420hp 6.8
391hp 6.3!
The 6.3 is a little different since the std intake manifold was similar to the race version, whereas the std 450/560/6.9 intake was very different to the race version. So obviously the modified exhaust helped.
If you use the CW311 as a benchmark (with a single throttle), 375hp from 6.3L is 60hp per L. So a theoretical hp increase for the 6.9 using the same (old) tech would produce 414hp.
Although in saying the 6.3s intake was similar to the race version isn’t totally correct since the race car had twin throttles. I doubt the exhaust alone could increase power by 100hp. So it’s possible the std engine’s throttle is also too small (like the 6.9). Other mods likely to contribute to the hp increase could include compression increase, cylinder head work (porting), bigger valves & modified cams.
The std 6.3 was also configured with main runners feeding same side primary runners. The race manifold used a cross ram design, which is more desirable for high torque. The std intake also incorporated injectors protruding into the airstream (which is far from desirable), however I have no idea what the race system utilized.
The Mampe race car incorporated rather large twin plenums, whereas the Red Pig did not. Not sure if that alone accounted for the differences in performance. The Red Pig had only 50hp more despite the capacity increase of 51% (4500 vs 6800cc).
Recall we eventually worked out that the Mampe car would've had to have many key components close to factory standard, since the series was a homologation one. I guess intake manifold may have been free, but usually under such circumstances throttle body (or at least venturi diameter) isn't. I'd expect injectors to be pretty standard too then, though as you say maybe farther from the port or otherwise a little more optimised. I'd guess now if its reported peak hp actually was accurate the simplest explanation for the Mampe car's numbers involved quite a bit of avgas and ignition advance along with the usual NA tuning suspects, in which case some different exhaust tuning can make quite a bit of difference
I guess slow progress is better than no progress!! 3D printing custom parts makes some of the tasks easier. This is a scan of the standard injector cup. More progress next week when I get a chance to finalize the last set of amendments….
S Mercedes Ute Articles 1
