Engine radiator replacement
More threads by BenzLover
BenzLover
Benz Whisperer
Capalaba,Queensland and Vancouver Canada
Hi Big Dan - another good site - I loved the transmission Hellicoil one you also posted. Keep up the good work!
BenzLover
BenzLover
Benz Whisperer
Thank you Sir.
Hi BenzLover, thanks for all that info and excellent pictures detailing the removal procedure.
Removal of the radiator on the 116s is somewhat different in detail. The principles obviously are the same or very similar, but even between the various 116 versions, viz. 280,450 and 6.9, the procedure can vary. The main difference relates to the radiator retaining clips that are located on the sides of the radiator and can be quite stubborn to remove and replace.
I have also found that, at times, the radiator is loath to be pushed upwards and I have had to retort to using a lifting jack to break the seal and obtain initial movement. Regards Styria
S Same Engine Articles 14
S Engine swap Mechanicals 7
