air con pressure switch
I need to change the Air Con. Hi/ Low pressure switch '81 280 Sl. Is there a schrader valve in the line to prevent the gas leaking out when the switch is unscrewed ? or does the gas have to be removed ?
Also i may have sorted the compressor stalling the engine by restoring the retard vacumm to the distributer ,setting the timeing to 10% before TDC all vacumm disconnected ( total mechanical 35% ) and 750 RPM air on and Trans in Drive. Preformance feels the same. Fingers crossed ! Thanks Sean
S Air Con mystery Articles 24
A Air con drain Mechanicals 3
S Air Bags Articles 5
Oversize Restrictive Air Filter Assemblies Mechanicals 50
J Aux Air Valve Mechanicals 2
motec 6.9 1954 Packard Caribean Con Talking Torque 5
A bent con rod Mechanicals 1
