560SEL Trans & Diff
Ok so I have the opportunity to buy a real rough and incomplete 560SEL. But I'm still wondering if it's worth having all those bits to worry about. It's an Aussie built in 10/86 with a VIN of W1260392A267775. It has a 72232302806667 trans (part # 1262707601) and a diff with a tag that says "Achtung: Spezial Ol Sperrdifferential", which I assume is an LSD.
So firstly: What are the ratios of both the trans and final drive gears?
What's the torque capacity of both?
Were brake boosters and master cylinders all the same across the W126 range?
What's the large ECU below the windscreen?
More importantly, will this diff fit into a W116 if I change the backing plate, or is that not required?
In the end I DID buy it! :D
A truly sad end to a once sensational car.... As I found it at the wreckers:
When it arrived:
As it is today:
So its a re builder then. :D:D:D
Mark, I am glad that you have a cover over the car. Interesting looking country side where you live. Do you in fact have any plans for the car ? I would have said no, but stranger things can happen. Regards Styria
If you look at my signature it's the third one down and the 'P' means parts, since there's a limit on signature length. I'll be using the seats, diff and brakes along with the valves. The rest is up for sale soon with an party interested in the short motor already
front brakes. When I get over. :)
Anyone else experienced wheel bolt failure like the one on this car? If so I have a way to remove them without destroying the wheel...
Hi mark it not something I have had to deal with but its normally rattle guns that jam wheel studs.
As a W126 owner it upsets me to see a W126 looking like that!
Look at the wheels on the 560!
:eek:
its what waits for your W126 Tim. :p:p:p
Ashes to ashes dust to dust given the time all Mercedes shall rust. :p:p:p
I will try to prevent it Tim. :D
Here's some recent pics of the engine. I lubed it up and confirmed the engine turns over so hopefully I'll sell the bits I don't need soon.
motec 6.9 RM AUCTIONS 560sel 6.0 Mercedes W126 0
Oversize Full House 560SEL Mercedes W126 1
c107 C107's 560SEL Mercedes W126 72
Oversize Midnight Express RUF 560SEL Mercedes W126 11
Oversize 560SEL with a twist... Gumtree/eBay/Facebook Listings 15
Patrick_R Patrick”s 560SEL Mercedes W126 38
Oversize 560SEL Barn find in Italy Mercedes W126 13
Styria 560SEL - For Sale Mercedes W126 2
260ebenz 560SEL for sale Gumtree/eBay/Facebook Listings 33
Oversize White 560SEL Wreck Mercedes W126 33
Oversize Champagne 560SEL Mercedes W126 37
Styria 560sel & 500sel Road Tests 3
Styria 1991 Mercedes 560SEL Websites and Links 1
Oversize 420SEL vs 560SEL Mercedes W126 21
Styria 1986 Mercedes 560SEL Road Tests 4
260ebenz LHD 560SEL for sale Gumtree/eBay/Facebook Listings 4
Oversize Euro 560SEL for sale? Gumtree/eBay/Facebook Listings 2
S Auto Trans demise Articles 22
s class 350 trans keeps pushing fluid out the overflow Technical Information 6
s class 350SE trans failure Mechanicals 11
S For budding Automatic Trans mechanics Mechanicals 13
A 450sl diff ratio Mechanicals 13
B Can anyone identify this diff? Mercedes R/C107 7
abl567 Diff dramas Mercedes W108 and W109 29
