Wanted Window Rubber Strips
More threads by Michel
Not sure of the name, but I am looking for some good used ones if anyone have.
I am told one can use the inside ones and swap the clips.
Any idea?
I also believe they are available new...
But I'm not keep on spending big at this stage as Bluey is on a tight budget (what budget????)
Pics below inside and outside
I'd call them weather strips (internal & external) and if they aren't still available new I'll be in trouble!! :eek:
Sometimes, you can be lucky.
I have often patrolled around a very large junk car yard and found parts from other cars that do the job better than the originals.
A lot of the trim clips in my 6.9 have been replaced by Toyota clips off junked Toyotas. They simply do a better job!
However, you have to be lucky. It is certainly worth a try, if you have the spare time. Exterior seals against the glass present the most serious problem.
Rubber seal strips will almost certainly be of the wrong length. OK if they are too long, they can be cut. If they are too short, the shorter lengths can be joined. I have done this with super glue. That stuff will NOT let go, when it comes to joining lengths of rubber strip end to end. I have done this on a Nisan Skyline.
I will check for you, Michel, and let you know. Regards Styria
Any idea?
It is called a weather seal or Window weather seal and the profile looks common enough Michel.
Id call Scotts old auto rubber in Melbourne as they sell popular profile rubber by the meter as well as trim clips etc.
http://www.scottsoldautorubber.com.au/
As for the Clips Id try GPI Automotive, Ive been buying stuff from them for years on and off and their trim and clip kit was pretty good from memory.
http://www.gpi.com.au/index.html
Thanks Tony, you've jogged my memory because Scott's (in Melbourne) and Jackson's in Sydney have the same stuff.
I'll drop by Jackson's this week, he's round the corner from one of my clients Concept Paints
My pleasure Michel,
I've had to chase some weird stuff over the years and although my memory seems to self wipe every so often Scotts stuck in my mind.
Just hold out for the felt backed stuff if you can.
A Wanted to Buy: 350 or 450SLC Feb/March 2022 Mercedes R/C107 13
Michel Wanted W108 doors Gumtree/eBay/Facebook Listings 2
B Wanted: Turbo diesel car Gumtree/eBay/Facebook Listings 15
Michel Wanted Mercedes W116 12
Michel Wanted for W116 Gumtree/eBay/Facebook Listings 22
mrkozzy w108 boot lid wanted Gumtree/eBay/Facebook Listings 3
Michel Wanted floor mats for W116 Gumtree/eBay/Facebook Listings 19
B Distributor Cap Wanted Gumtree/eBay/Facebook Listings 16
motec 6.9 wanted amg spoiler Exteriors and Body Repairs 6
BenzBoy Veteran Wanted Gumtree/eBay/Facebook Listings 22
Styria Keen Restorers Wanted Exteriors and Body Repairs 4
Styria wanted ! Buyers of W116 Compact Disc Gumtree/eBay/Facebook Listings 21
Des WANTED; books Gumtree/eBay/Facebook Listings 3
Des Wanted: D Plate Gumtree/eBay/Facebook Listings 7
BenzBoy Wanted - dashmat for W116 Gumtree/eBay/Facebook Listings 6
