Transmission Kick Down
Most Kick down issues are a result of lack of Pedal travel ie the Pedal hits the floor. Just plain old wear and tear. With a Rod system it can be sorted by just pulling the Pedal up to bend it some what.
Better not to use Kick Down, as it usually triggers full throttle,,,, not always needed nor wanted..... I use the gear lever to select a lower Gear and then :)the Throttle as necessary. If the Engine is in good Tune and the linkage in good order and set correctly then a part throttle downshift can be obtained.
This applies to all Auto Boxes. Holden Trimatics were horrible Cars to drive as the Factory settings held Top gear till the death. A simple change of a Valve Body Spring transformed the driving experience. :)
S Transmission - Valve Body Mechanicals 4
abl567 Wanted T350 Transmission Gumtree/eBay/Facebook Listings 4
S Transmission Mercedes W116 1
B 10-Speed Transmission Websites and Links 3
S drain plug Transmission Mechanicals 5
R 450SE harsh transmission shifts Mercedes W116 15
motec 6.9 722.300 Transmission Manuel Mechanicals 41
300SDude Transmission Question Mechanicals 3
Oversize 6.9 Transmission Upgrade Mercedes W116 76
MercedesMike 6.9 Transmission Pump Mechanicals 8
WGB Automatic Transmission Manual Part 1 Technical Information 1
Michel V8 Mercedes Engine and Transmission complete Gumtree/eBay/Facebook Listings 0
TJ 450 6.9 Transmission Rebuild Mechanicals 4
J transmission swap Mechanicals 0
abl567 6.3 Transmission howl Mechanicals 15
s class W140 driveline/transmission issues Mercedes W124, W201, W140 and R129 7
Michel Complete Engine And Transmission in Victoria Gumtree/eBay/Facebook Listings 4
S Lock Down Articles 0
Styria Feeling Down and Out Websites and Links 3
S low down Torque Mercedes R/C107 12
Michel Mercedes-Benz SL: Well Thought-out Right Down to the Smallest Detail Articles 0
garrye 450 slc breaking down under acceleration Mercedes R/C107 6
