Servicing 6.3 Injection Pump
This is probably one of the most important, and dare I say, troublesome aspects of driving the Chassis 109 - 6.3. The main problem relates to the overfilling of oil from the main body of the pump to the Governor housing. As a result, the petrol mixture is compromised by oil contamination, causing the car to run rich, fouling plugs and resulting in diabolical fuel consumption.
We have located a source/fuel injection specialist that will carry out a major resealing operation, service the pump and bench test the unit. The cost is $A1900.00, but that does not cover any 'hard' parts.
Pump on bench with side cover removed
On test bench, hooked up to calibration machine.
Checking amount of flow:
Thousands dollars worth of Snap-On tools, not to mention the equipment and machinery in evidence. For anyone interested in having those pumps serviced, please send PM to myself. Regards Styria
That pump is a magnificient piece!!! What a job to service it though...
Hi BenzBoy, it is a complex piece of machinery. Normally you will pay in excess of $A2.5K. from other sources - and they are difficult to find. Regards Styria
260ebenz Car servicing article Articles 4
450SE Servicing / Mechanical repairs, Melbourne Recommended Suppliers 0
L Power Window Servicing Interiors 11
S Direct injection Articles 1
abl567 Injection pump replacement. Part 2 Mercedes W108 and W109 3
Styria 6.9 Water Pump replacement Technical Information 37
A water pump Mechanicals 7
