Koni front shocks for W116 on eBay USA
More threads by B13
Bilstein - I've never been able to make Koni's last.
Koni's are probably OK for track use - especially the adjustable ones but when the price is similar durability counts.
Well, the current bid is certainly on the correct side of the ledger. I used to buy Koni shocks quite regularly years ago as I used to get a great discount from Proven Products in Guildford who were the importers for Konis at that time - I am talking at least ten years ago.
In those days, I knew a fair bit about Rovers in general and still have some. However, I used to compare the genuine Rover Shocks with Konis and found that Rovers had a larger body with a much thicker shaft. Whether or not that made the Rover product better, I do not know. Howewer, just recently, I disposed of heaps of Koni as well as Monroe dampers, and kept some geniune Rover units as they appeared to be in better condition. Regards Styria
Ian,
did you end up getting them?
No, I was tempted, but I never thought I'd find a set of matching rear Koni shocks.
Also, the RX4 race car which runs a Koni setup has hydraulic Koni's, as for tarmac I think they have better control than the gas ones. If I could find a complete set of hydraulic konis for a 116 i'd snap them up for sure.
260ebenz Amazing what a new set of shocks can do! Exteriors and Body Repairs 3
