Is your door difficult to open?
More threads by BAR
I had a 'stick' front passenger door lock and having some time on my hands spent a while inspecting the design and fabrication of the mechanism to see 'what I could see'.
The door handle itself is removed relatively simply. Take off the inner trim [grab handle - arm rest, small chrome plated triangle near the door mirror, door mirror plastic arm, trim at rear of door, chrome surround near door latch and then lift up and off the inner trim], then undo the srew holding the front of the exterior handle and then remove the oval shaped rubber plug at rear of door and undo the two allen key rcrews.
With the handle removed one can easily see a 3-4 mm pin [which can be undone with a blade screwdriver]. Moving this pin towards the handle proivdes a more positive action on the door latch and enables the door to open more easily [as was the case for mine].
Also there's a sping balanced counterweight, which is loose makes a clunking noise as the door is shut.
Tightening both of these makes for an easier opening door latch and reduction in 'tinnieness' when the door is opened and shut. Voila!
Sorry I didn't take pictures to better illustrate my post.
Hi Bar, I hate to tell you, but you really made quite a bit additional work for yourself.
To remove the door handle, all that's required is to prise off the little plastic cover which hides the two Allen headed bolts. Undo those, tap the handle towards the front of the car and it can be removed. There is no need to touch any of the interior trim.
I am not knocking your efforts as, in any case, someone else on Topklasse would have advised you similarly. Regards Styria
Regards Styria
Don't you love that.....
After all this effort..... :eek:
Ahh so!
Thanks for the easy solution. ALways nice to get the right advice from the pirate.
Fortunately I am not gutted to know the quick method: I had to get the door trim off to remedy a leak in the door lock belows, so no time lost for me on this exercise, but I won't be doing the same in the future.
Ahh so!
Hi Bar, don't worry too much about having to learn - I am still doing so !
Talking of learning and finding out, you just have to tell me why I am the 'pirate' ? I thought that Godfather, as Michel christened me some time ago, was a somewhat more appropriate title or description. :eek: Kindest Regards Styria
Indeed..... Godfather you shall remain...
Pirate :confused:
Doesn't a pirate need a parrot?
mmmm, Styria has a parrot...
Parks
im guessing cos you used to have a smoke hangin out the side of your mouth 24/7 ?? :rolleyes: but I could be wrong:D cos didnt pirates have like a pick or something hanging outa their mouths all the time?/:confused:
I'm stopping here....
This is going on a wild tangeant :eek:
I've yet to see a PIRATE with a BUDGERIEGAR but I am willing to believe as it is before 11 AM. Apologies to Lewis Carrol....
Now; the wooden leg. Parks, can you help here? He'll want it upholstered too, you know. :rolleyes:
Pirates have been stereotyped as having a parrot on one shoulder and also having a liking for rum.
It stretches the image, however Styria does occasionally enjoy being accompanied by his bird and at the correct time of day, enjoys his glass of port. There it ends!
Hi Bar, you're right on all counts. I do indeed take him to various places, such as Service Stations, Parklea Markets and the like.
He particularly likes Parklea where he (she ?) helps me to pack my fruit into plastic bags, but he insists on checking things first - particularly grapes. He's also been known to chirp and whistle, and some people have been totally confused in looking around for the source of the noise.
A great little mate and you should have seen his antics when I came back from Europe.
Yep, that's him. Regards Styria
Styria, does he/she say "pieces of eight"
Don't let Sarah Palin anywhere near him....
I know she's a mouse hunter, but you never know :eek:
P dodgy electric window regulator drivers door. Mechanicals 2
P W116SEL door handle Exteriors and Body Repairs 16
C 280E Door rubbers and seal Mercedes W123 4
J Frozen door lock Articles 20
motec 6.9 AMG GT 4 door Road Tests 0
6.9forever RHD 107/116/123 driver's door mirror Exteriors and Body Repairs 2
Oversize Nice door treatment Interiors 2
motec 6.9 300s 4 door cab Mercedes W186, W188, W189 and W100 2
motec 6.9 4 Door Sbarro Talking Torque 2
300SDude Vacuum Door Lock issue. Mechanicals 14
300SDude Removing inside door panel? Interiors 21
Michel Door Trims for W116 SEL Gumtree/eBay/Facebook Listings 3
T W107 Door Strap Mercedes R/C107 5
Oversize Fastest 4 door sedan? Motorsports 10
B FS [melb]: W116 interior parts (black), seats, door cards, etc. Gumtree/eBay/Facebook Listings 2
A Vacuum, door locking bellows Mechanicals 6
Styria Right back door jammed shut- HELP Exteriors and Body Repairs 22
mycar450slc problem with key/door lock Mercedes R/C107 14
SEL_69L SEL 6.3 two door coupe.... does anyone know where it is now? Mercedes W108 and W109 5
A 1974, 450SEL front door handle, inner RH Mercedes W116 3
BenzLover Door lock actuators... Mechanicals 0
Fotografa Wanted - R107 SL Driver's Side Door Gumtree/eBay/Facebook Listings 2
B Repairing Door Lock Actuators - money saver Interiors 10
Des strange door trims Gumtree/eBay/Facebook Listings 12
G W116 window and door trim strips dull Exteriors and Body Repairs 31
Styria Front and Rear Door Trims Interiors 9
Michel Door Plastic Weathershields Gumtree/eBay/Facebook Listings 2
Oversize Open Cheque Refused Mercedes W116 5
A Boot wont open Mercedes R/C107 41
Michel The World’s Most Exclusive Open-Top Luxury Saloon: The New Maybach Landaulet Talking Torque 11
