450SEL / 6.9 Common Mechanical Parts
More threads by Lukas
Hi all,
Well, am back from O/S, and finally in the home straights of dismantling the 450 so I can get it out of my front yard. The neighbours will be pleased.
For those not familiar:
TK - Dismantling
TK - Pictures
Question today is, which mechanical parts are common between the 450 and 6.9 (M117 and M100 engines)?
Best I can tell:
  • Fuel Injection - K-Jet: same
  • Alternator: different
  • Hydro pump (from the 450's SLS): same
  • SLS rear valve: same
  • Ignition leads: different (5kohm vs 1kohm on 6.9)
  • Water pump: different
Not sure about:
  • Power steering pump - different labels on them, but otherwise look similar?
  • SLS rear struts - any matches to a 6.9?
  • Fuel system (fuel pump and hangers on) - am guessing same?
  • Main radiator fan (metal one) - looks same?
  • Radiator (compared to Aus 6.9 - no oil cooler) - same?
  • Ignition coil?
  • Dizzy?
Please advise if you know about the second list, and of course correct errors in the first.
Ta
Hi Lukas, welcome back from O/S. Just as an aside, and not part of this thread, and unless private, you may tell us about your trip. I vivdly recall your photos and comments on your trip to Cambodia - it made interesting reading and looking.
Your lists: - SLS rear valve different.
Front and rear shocks different.
Leads - 5 ohm vs. 1 ohm - not all that important, but lengths
are different.
Of course, struts are different.
Fuel System the same
Coil and Dizzy the same
Ignition unit - the same.
P.S. pump slightly different, but can use on 6.9.
Intake manifold not interchangeagle.
Fuel Distributor same - it is K-Jet, isn't it ? Your car, that is.
Rear Calipers and rear discs, also front discs the same.
Front and rear suspension - just about interchangeable. Diff
and flexible couplings different.
I could probably think of a couple more. Just ask. Regards Styria
L
Thanks Styria - exactly what I was after. I was not looking forward to trying to remove the rear SLS valve, so it can stay there. I'm about to head out now and pull the fuel system, ignition system and PS pump.
Am not worried about the brakes or (common to 6.9) suspension bits - they are generally hard-wearing, or in the case of brake pads and discs easily (and reasonably cheaply) purchased as replacement parts should I need them.
Will also keep the rims - just 14" Bundts, but good nick. Then the car can go off to the scrappers.
Will post holiday pics at some point soon, and a few more of the car in bits. Trip was to Malaysia and Thailand.
PS - what about the main radiator fan and shroud, and the radiator itself - is that worth keeping (maybe to get re-cored), or is it simpler to just get a whole new one should the need arise?
Ta
Some of the body parts varied between early and late 6.9's, in the area of trim. From what I can figure out, the sheet metal body pressings are the same for all SEL's. There are very many other body parts that are common throughout the W116 production.
This may sound strange, but my 6.9 has some body fixing parts from modern Mitsubishis and Toyotas I would challenge anyone to find where I have used these parts, though!
My car has 15" wheels from a 126, and they are perfectly OK, with the correct width and offset. They are shod with tyres that are spec. width for a 6.9, and the OD of the tyres are within 0.5% of spec. OD for a 6.9. They are 225 65 15's. Beware! It is easy to get the wrong offset with this wheel pattern, e.g., with wheels from a W124.
That makes tyres $100 per corner cheaper to replace, as well as much easier to find. Some professional tyre advice is required to find the tyre that has the best load carrying capacity for that heavy cast iron engine, which makes the car more weight biased to the front than any other W116 type. The tyre solution comes down to case construction and speed rating thus the need for good professional tyre advice. In terms of robustness of construction, speed rating and load carrying capacity are closely related.
QLD6point9 Donor 450SEL and 6.9 #5370 progress Mercedes W116 6
6.9forever Catalan 450SEL restoration that must be seen to believe! Mechanicals 1
Oversize Differences between a 450SEL & 6.9 Mercedes W116 4
6.9forever Icon Gold 450SEL in good condition Gumtree/eBay/Facebook Listings 3
4 1975 450SEL for sale $1000 Mercedes W116 7
260ebenz 450SEL 6.9 for sale Gumtree/eBay/Facebook Listings 32
S What to do with a 450SEL Mercedes W116 3
Styria 1978 Mercedes 450SEL 6.9 Gumtree/eBay/Facebook Listings 9
4 Petrol smell in cabin of 450SEL 4.5 L Mercedes W116 7
4 1975 450SEL for Sale in Sydney Gumtree/eBay/Facebook Listings 6
260ebenz 450SEL 6.9 drive Mercedes W116 6
O A couple of 450SEL qns from a new guy Mercedes W116 15
Oversize Two Tone 450SEL Gumtree/eBay/Facebook Listings 10
motec 6.9 Black Euro 450SEL Gumtree/eBay/Facebook Listings 6
260ebenz 1974 450SEL 64,000 miles Mercedes W116 7
Styria $a100k - 450sel 6.9 Websites and Links 1
B 450SEL 6.9 for sale in South Australia Gumtree/eBay/Facebook Listings 20
260ebenz 450SEL for sale Mercedes W116 1
Michel 450SEL For Sale (2nd Owner) Gumtree/eBay/Facebook Listings 30
260ebenz Michel's 450SEL Mercedes W116 5
260ebenz 450SEL for sale Mercedes W116 5
260ebenz 450SEL 4.5 for sale Gumtree/eBay/Facebook Listings 5
Styria Mercedes 450SEL 6.9 Road Tests 0
motec 6.9 2xNice 450SEL on Carpoint Gumtree/eBay/Facebook Listings 10
L Chopped 450SEL Mercedes W116 4
motec 6.9 Nice 450sel for Tony Gumtree/eBay/Facebook Listings 2
WGB 450SEL - wakening after long sleep Exteriors and Body Repairs 20
motec 6.9 Nice 450sel Gumtree/eBay/Facebook Listings 2
Oversize 450SEL for sale Gumtree/eBay/Facebook Listings 9
Oversize 450SEL sold for $1500 Gumtree/eBay/Facebook Listings 0
Tony66_au 450SEL 6.9 for me? No. Mercedes W116 7
300SDude Craigslist 1975 Mercedes W116 450SEL - $3995 Gumtree/eBay/Facebook Listings 6
300SDude '76 450sel $800 Gumtree/eBay/Facebook Listings 0
