Brake Caliper Rebuild
More threads by Lukas
Hi all,
Been quiet for a while at my end - I only just managed the Christmas oil changes, and late as usual.
The Green 450 showed a leaking front left brake caliper the other week, so that forced me into action on the MB front. I was quoted ~$500 to rebuild both fronts if the pistons were OK (more if not), so I went to good old Autohaus AZ and got some caliper repair kits for about $120 posted for all 4 corners.
The leaking front took 5-6 hours to remove, rebuild and replace, while the other front was much quicker once I knew what I was doing.
With both fronts rebuilt the car is stopping well again (and no more leaks) - will do the rears at some point too. Both fronts had the dust caps perished.
Technique-wise, I just followed the Haynes manual. I found it easier to leave the sensors and pads on while removing the calipers; and used low-pressure compressed air to pop the pistons out (with the old dust caps still fitted).
The biggest surprise was the poor condition of the brake fluid - detergent green due apparently to corrosion. It turned to DOT4 honey yellow after bleeding. The fluid reservoir also has lots of gunk in the bottom, but no nice way to clean it out - will try to get a large syringe for that. I'm on a mission now to stock up on brake fluid and bleed all the cars.
Very cool Lucas . good to see some work going ahead I am looking at returning to Canberra at the moment. So it would be cool to not only be only W116 tragic in town . :D
Good job, and yes brake fluid should be changed every two years. We rarely see leaking calipers in the shop any more since making brake flush part of our service routine about 15 years ago.
The 116 chassis cars come with two Caliper versions - on my Gleaming Beauty, they are made by a Company called ATE. However, on my 1977 450SE, they are Bendix unit. Whatever the problem was, I am not sure, but I found it quite difficult to properly install the dust seals on the Bendix units.
In days gone by, I have come across where no amount of compressed air would expel the pistons from the Caliper body. To overcome the problem of a sticking piston, I made up some grease nipples that were fitted to the Caliper, and removed them with compressed grease applications. Very, very messy, and it would take ages to clean them out thoroughly. Regards. Styria
Styria 6.3 Brake Caliper Features Mercedes W108 and W109 2
P My experience with silicon brake fuid Technical Information 1
S Brake Pads Mechanicals 4
S brake balance Mechanicals 3
motec 6.9 P11 Shooting Brake 67XJ Gumtree/eBay/Facebook Listings 5
Styria stainless steel braided brake lines Recommended Suppliers 0
Styria Braided Stainless Steel Brake hoses Websites and Links 0
Styria 6.9 - Brake Master Cylinder Mechanicals 16
SELfor50 Brake Failure - Post Race Analysis Mechanicals 8
Styria Brake Calipers - pistons rusted in Mercedes W116 24
J Warped brake discs? Mechanicals 14
Styria Changing Brake Fluid Mechanicals 31
WGB Power Brake bleeding Mechanicals 2
Andrew280SEL Brake Clunk....? Mechanicals 16
J 450sl rebuild?? Mechanicals 9
Styria Starter Motor Rebuild Articles 1
SELfor50 380SEL - Total Engine Rebuild Gumtree/eBay/Facebook Listings 9
Nütz Evil Servo Rebuild Mechanicals 2
