- Thread Starter
 - #21
Ok here's some info that I've copied from another site where I discussed a transmission upgrade:
Mark, 560SEL got the 722.323 and the 420 got a 722.324. It appears the 722.3 transmissions used behind the V8 cars were W4A-040 units, with 040 being the torque rating in mkg. The V12 cars had a 722.362 unit which was a W4A-055. 40mkg is about 392NM or 289lb/ft. 55mkg would be about 539NM or 398lb/ft of torque. Considering that the 6.9 transmission was rated at 050, I think the V12 unit would work, although you could probably get by with a 560SEL unit as the euro version of that engine was pretty damn close to what a 6.9 made. I may be incorrect on the mkg vs nm. The early transmissions in the late 60's were rated in Mkp or mkg, the later ones may in fact be rated in NM, so the ratings would actually be a bit higher....400 and 550NM.
Chris in Phoenix
That doesn't sound right because if a Euro 6.9 can produce 550Nm, it'd blow up both it's own trans, plus that of the V12. From what I've heard the Aussie 600SEL produced 300Kw and 580Nm and would also grenade it's own trans going by those figures
Mark
Well, the 6.9 transmission was a W3B-050 and the 050 is the torque rating of the transmission, either in mkg or nm. They never made a 3 speed with a higher torque rating. The 6.3 was a K4B-050, same torque rating, but a 4 speed with fluid coupling. Also remember in engineering there is usually a "cushion" built into the specs....I would imagine the rating of 500NM is a bit on the conservative side, with the actual capacity being a bit higher.
No electronics, 722.3 transmissions were all mechanical. No lockup converter either. Also, the 722.3 was used in Porsche 928.
Chris
Chris in Phoenix
Mark
Chris
