W140 parking brake, upper control arms, steering assistance
More threads by s class
More W140 work this evening.
I removed the valve covers for a once-every-so-often inspection of the cam oilers. These little devices have machined oil galleries, and one of the ports is closed off during manufacture by a small steel ball, and the casting is peened to keep it in place. Unfortunately these balls can and do break free - a known M119 weakness. The consequence is that this ball then is free in the valve area, and the corresponding cam and tappet go short of oil. Symptoms include persistent valve ticking and eventually cam damage. Prudence is to do periodic inspections of these oilers. Simple enough heh? Well yes, but from the start of stripping to having the engine running again is at least 90 minutes due to the amount of stripping.
At least I can report all the oilers are still good - a happy state of affairs as replacing the oilers involves releasing the camshaft bearing caps. Not nice.
I then got on with removing the handbrake shoes - necessary because during a recent business trip, I was travelling home about 250km at 3am, after a 20 hour day, pulled over to take a break, and when resuming my trip was to tired to notice the handbrake was still on. Those poor little handbrake shoes were no match for 300hp of quadcam v8 over the next 100km. The handbrake shoe arrangement is almost identical to the W116, thhough the clearance adjustment mechanism is of a considerably improved design, and much, much easier to adjust than trying to blindly twiddle that little toothed wheel inside the drum in the W116's case.
I also pulled off the front upper control arms to investigate the clonking they have developed. Can you believe, MB does not provide a bushing kit for them. The arm has to be replaced entirely, for some $400 per side. Ouch. Autohaus does offer a cheaper Meyle alternative for around $100 plus postage per side. Anyway, these upper control arms have hydraulic bushings, and mine are well past their best. ho hum.
Oversize W140 600SEL Mercedes W124, W201, W140 and R129 18
motec 6.9 Series 2 W140 S320 Gumtree/eBay/Facebook Listings 14
260ebenz V12 w140 Gumtree/eBay/Facebook Listings 7
motec 6.9 W140 S600 developement video Road Tests 0
motec 6.9 96 w140 s280 Mercedes W124, W201, W140 and R129 91
motec 6.9 W140 Ko 860 Sleeper Road Tests 13
260ebenz Bulletproof V12 W140 Gumtree/eBay/Facebook Listings 0
260ebenz Diesel W140 for sale Gumtree/eBay/Facebook Listings 3
Styria Mercedes W140 - 600SEL Road Tests 5
Styria Mercedes 'S' class W140 Road Tests 1
A v12 motor from w140 Gumtree/eBay/Facebook Listings 19
motec 6.9 W140 with 16000km Gumtree/eBay/Facebook Listings 5
motec 6.9 Armoured w140 Gumtree/eBay/Facebook Listings 4
motec 6.9 w140 S600 Gumtree/eBay/Facebook Listings 22
mathew W140 OBD1 or OBD2 Technical Information 6
mathew W140 Buyers Guide Mercedes W124, W201, W140 and R129 10
L W140 s500 Mercedes W124, W201, W140 and R129 22
Des W140 Mercedes W124, W201, W140 and R129 31
116Benz W140 S700 AMG Coupe Mercedes W124, W201, W140 and R129 17
S Parking Sensors Technical Information 17
260ebenz 450SLC parking sensors Mercedes R/C107 2
P My experience with silicon brake fuid Technical Information 1
S Brake Pads Mechanicals 4
L Brake Caliper Rebuild Technical Information 3
S brake balance Mechanicals 3
motec 6.9 P11 Shooting Brake 67XJ Gumtree/eBay/Facebook Listings 5
Styria stainless steel braided brake lines Recommended Suppliers 0
Styria Braided Stainless Steel Brake hoses Websites and Links 0
Styria 6.9 - Brake Master Cylinder Mechanicals 16
SELfor50 Brake Failure - Post Race Analysis Mechanicals 8
Styria 6.3 Brake Caliper Features Mercedes W108 and W109 2
Styria Brake Calipers - pistons rusted in Mercedes W116 24
J Warped brake discs? Mechanicals 14
Styria Changing Brake Fluid Mechanicals 31
WGB Power Brake bleeding Mechanicals 2
Andrew280SEL Brake Clunk....? Mechanicals 16
