Unusual 107 parts
More threads by garrye
garrye
penrith
Today I picked up a metal heater blower cover and a brass overflow radiatar tank. Does anyone else have these items, as my existing ones are plastic?
Cheers Garry
Hi Garry, I think those metal parts were produced for the earlier models. At some stage, they changed to plastics. I have/did have (?), probably still do (I have to check) a metal overflow tank that took a bit of doing to stop it from leaking at the seams - it comes in two parts. Other than that I can't tell you any more. Regards Styria
garrye
garrye
penrith
Styra, thanks for your reply, i was unaware these exsisted
Hi Garry, I can do a bit better now, as I have found the metal overflow tank that I had repaired and then painted. In the picture below, there are in fact four types of radiator overflow tanks. Obviously, the black one is the one that (I think) you are referring to.
That one , as it comes in two halves, has been pulled apart and re-soldered professionally. I had used it on Gleaming Beauty purely for curiosity value, but as it kept on seeping, I decided to replace it with the latest type plastic unit - that is the one with the strengthening ribs. When buying those, you will also need to purchase the plastic plug and circlip to close off the opening for the temperature control unit. That unit, incidentally, cannot be used on a 116 on account of the close proximity to the battery. Another so called drawback is the large outlet for the hose that leads to the bottom of the radiator - it is a very special hose with unequal sizes at either end and will set you back at least a hundred dollars (when I checked about four years ago).
There is also the earlier type plastic tank - the same as the black metal one, and with both you can use a far simpler hose, probably procurable from outside sources. So that can be an advantage. Last but not least, the bullet shaped overflow tank - made of brass and taken off a 1968 - 300SEL. I believe they have a similar, if not the same unit, on other Mercedes models as well. It is for sale, if anyone was interested for $60.00, as are the black metal one ($45.00) and the old style plastic unit for $25.00. Regards Styria
N.B. Apologies - for some reason, Photobucket is not allowing the transfer of the photo. Will have to sort that out. Photobucket working again.
s class unusual and messy instrument failure Mechanicals 7
c107 107 107's across the Harbour bridge Car Show Photos 5
c107 A couple of 107 reviews Road Tests 4
Oversize Very nice 107 SLC Mercedes R/C107 1
M 107 Mercedes R/C107 2
CraigS I have joined the 107 club ! Mercedes R/C107 14
S dash covering 107 SL Interiors 24
S SL 107 safety Mercedes R/C107 0
S 107 Imports Mercedes R/C107 6
S Sale of 107 Mercedes R/C107 4
S hood Pad 107 Mercedes R/C107 3
S wind deflecter 107 Gumtree/eBay/Facebook Listings 0
Styria 107 Meet in Holland Talking Torque 6
Styria Unhappy 107 - SL Exteriors and Body Repairs 11
Styria Fantastic 107 site Websites and Links 0
Styria Useful 107 information Mercedes R/C107 0
A 107 break upgrades Mercedes R/C107 10
Styria 107 website - northern source Websites and Links 0
S 107 Width Mercedes R/C107 9
T Mercedes 280SL 107 Mercedes R/C107 8
Styria Blinker relay - 116's and 107's Interiors 6
Styria Fitting new rear brakes to 107 Mercedes R/C107 2
J New-old-stock 107 mats Interiors 1
B For 107 fans 350SLC manual - pity its not a 350SE.. Gumtree/eBay/Facebook Listings 7
J Vapor lock with 107's Mercedes R/C107 2
J 107 Hardtops on eBay USA Gumtree/eBay/Facebook Listings 0
Des 107 SL and SLC Subframe Recall Mercedes R/C107 0
S Parts off C Class W203/w204 Exteriors and Body Repairs 4
Oversize Scored some parts manuals! Articles 1
