ABS on your W116?
More threads by Des
Shpuld be able to buy parts for ABS it was introduced on the later W116, in August 1978, Mercedes-Benz was the world’s first motor manufacturer to officially introduce the new ABS. In December 1978, ABS became optionally available, initially in the S-Class at an extra charge of DM 2,217.60.
Pictures of 116's are shown together with history of ABS at this site:
http://www.worldcarfans.com/5051116.001/daimler-benz-first-generation-anti-lock-braking-system
As a retrofit, I would be sceptical. One would require many components to be installed and or replaced. Once done, the whole system would need to be inspected and certified by an engineer. THis cost may be just the difference between consideration of an upgrade or just going out and finding an ABS equipped vehicle.
motec 6.9 1980 6.9 with ABS Mercedes W116 16
T W116 6.9 HPF spheres: keep front and rear references separate Mercedes W116 2
QLD6point9 W116 seat spring reinforcement Interiors 1
Oversize W116 Jacking Points Mechanicals 6
Oversize Some W116 Screensavers Mercedes W116 16
