W126 hood pad replacement
More threads by Aleksi
Aleksi
Aficionado
Helsinki, Finland
My w126 had the original hood pad and was falling apart. There were few replacement choices to choose from ranging from 30 euros to 150 euros from the Mercedes dealer. I decided to buy from the dealer. The new pad was clearly for the diesel model because it had the heat shield. It can be removed so it doesnt stand out. The glue i used was Teroson SB2444 from autodoc 20 euros per can. I bought two cans. If i understood correctly it is the exact same glue the mercedes dealer would sell me at a higher price.
I removed most of the old pad by hand and finished with a pressure washer:
The new pad and the turbo heat shield:
I did not realize how fast glue can dry.🤦‍♂️ There is no extra time to apply it evenly:
After installation:
It has stayed on so far. I think the original one wasn't properly glued on by the factory. Time will tell how this stays on.
I wouldn't attempt this alone without help. There is not much time to get it right and things can get messy with the glue.
How did you manage to hold the pad while glueing?
You did not remove the bonnet (hood) and placed it on a stand to do that?
Contact adhesive works well if used properly
I'm about to purchase one for my 380SE and one for my 300TE.
I'll let you know how I go ;)
The hardest thing about contact adhesive is lining it up before sticking on the pad. If you use it properly & apply it to both surfaces before letting it go tacky, it’ll sick the pad fast & wont allow realignment. You’d definitely need at least 2 people to assist if you’re not removing the hood from the car.
I know I'll be removing the bonnet off each car...
I reckon it would make it so much easier.
Maybe, but its such a simple job I wouldn't bother.
I've done it to most of my cars on my own, and it takes about an hour per car:
I prefer to remove the bonnet from the car for two reasons. First of all, removing all old insulation is messy and it is much easier to scrape off all the old glue with an Orbital Sander and, futhermore, all the crumbly foam is simply removed from the car. As far as application of the glue is concerned, I use a Spray Gun to apply the glue evenly and thinly and, as a further precaution, I apply the glue a second time (that's all to the underside of the bonnet), and I also use a fine spray on the insulation pad itself.
Leave the glue to settle until almost dry and then offer up the pad to the bonnet taking care to tuck the material at the front first and then work your way to the rear of the bonnet. It is important to tuck the pad neatly into all the various crevices, especially at the front and both sides. Even though the spray of glue is quite fine, once the two sprayed surfaces touch, contact is immediate so you've got to get it right. Parks (my son) can carry out this fitting with the bonnet in situ, but he is a highly skilled professional trimmer., so he is certainly one up on me. Regards Styria
Oversize W126 Exhaust Performance Upgrades Mercedes W126 70
Oversize W126 Book Articles 4
