W123 power steering
My brother is bringing over his W123 tomorrow as he has been complaining that at full lock the steering is making groaning noises (more than cars normally make on full lock).
I first told him to check the fluid level in case the pump is sucking air, whcih he has - it was a bit low so he topped it up, but only a bit low.
I changed the idler arm bushing and one of the track rods for him about two years ago, so I guess these could have gone bad, but I'm thinking probably not.
My next things to check will be:
  • The other track rod
  • the steering shock
  • the condition of the hoses in case they have perished and are allowing air to get in
Just a general look at the steering system when its up in the air.
We'll see tomorrow if it is any of these.
So the sound was a belt squeal, and the problem is that the bolt that allows you to hold the pump in place to tension the belt is no longer doing that.
So the nut just spins, and doesn't tighten or loosen. This means we can't even remove the bolt to replace it. Not sure what the next steps should be, so interested in any suggestions. My assumption is that the threads have stripped.
A couple or things you an do. Try putting outward pressure on the nut with a flat blade screw driver whilst undoing the bolt. Cut the nut off with a nut splitter. Or use a die grinder to grind the nut off.
Thanks, we'll give it a go. Is there anything special about this bolt (i.e should I get a mercedes one), or is just any old bolt I can take to the bolt store in brookvale and get one with the same size and thread?
Does it have the star adjuster at the head end ? If not its just a bolt :)
c107 C107's 1981 240D W123 Mercedes W123 37
c107 Colours for the W123 Mercedes W123 0
Oversize Black W123 280CE for sale Gumtree/eBay/Facebook Listings 2
Andrew280SEL My W123 230E (plus update on other Benzes etc) Mercedes W123 17
Andrew280SEL Anything I should know about the W123? Mercedes W123 30
motec 6.9 W123 280e 6.3 Mercedes W123 0
hoddo 2 w123 parts cars Gumtree/eBay/Facebook Listings 7
260ebenz 1982 W123 Hybrid plug-in Articles 6
motec 6.9 W123 280E MbSpares Gumtree/eBay/Facebook Listings 0
motec 6.9 Amg w123 Mercedes W123 4
260ebenz W123 brochures Mercedes W123 0
Tony66_au W123 & W124 SLS delete kit Mercedes W123 3
260ebenz 300TD wagon for sale- W123 Diesel Gumtree/eBay/Facebook Listings 2
B W123 in Swedish drift championship Motorsports 8
B W123 230 and 230E - whats the petrol economy? Mercedes W123 5
Des 1980 W123 250 For Sale Gumtree/eBay/Facebook Listings 41
Des Interesting interior mods W123 Talking Torque 4
Des Offtopic, Starting problems with my W123 250 Mercedes W123 14
S Battery Power Technical Information 7
S Power difference Technical Information 0
motec 6.9 6.9 power and Rumours Mechanicals 13
OzBenzHead Power Brakes South Australia Mechanicals 6
WGB Power Brake bleeding Mechanicals 2
L Power Window Servicing Interiors 11
