Guys,
I would appreciate your thoughts on this, on my 1980 W123 250
My 250 seems hard to start, it turns over over over fine, like it is turning over quickly enough, but it won't fire for say 15-20 seconds, I don't let it turn over over over too much without stopping, eventually it fires up and then proceeds to idle away fine,
if you were to stop the car and then switch it back on again it would fire up fine, it is only if it is left for more than a few days that it is hard to start.
So if I started it up today, started it tomorrow it would start fine.
I don't believe it is fuel/carby related as pumping the pedal a few times before starting and/or pumping it while starting doesn't seem to have any noticeable affect.
I don't believe it is the battery, as it turns over quick enough, i.e. it doesn't sound like the battery is dead or flat, you know that sound, where the motor isn't turning over fast enough.
I am wondering if it is something in the ignition? I don't know what though, coil? condenser? etc..?
I understand the W123 250 has electronic ignition, but that's about all I know about it
Thoughts?
comments?
Thoughts?
comments?
