A W116 with a difference
After a bit of sorting out, this should go like the clappers...:D
but not around corners..:confused:
Michel and I have witnessed the speed and acceleration capabilities of this engine when installed in a Nissan that used to be owned by Mercules. He reckoned at about 160k's he had another gear to go, but by this time and at that speed I decided that caution was the preferable part of valour. Certainly a very fast conveyance. We attained those speeds on the Hume Highway back from a Topklasse outing. :D Talk about responsibility and safety !
A bloke i know in Sydney had one in a VG Valiant sedan, his biggest issue was finding a stopping solution which he finally did after sourcing a Baer system from the US at my urging.
The thing was a missile and ran an aftermarket Engine management system and dedicated LPG to get around the plumbing for injection issue.
It replaced (the lexus donk) a fairly HiPo Mopar big block and he was more than happy with the result.
They are a great transplant and will outshine the perennial favourite the SB chev.
Engine notwithstanding, and assuming that photos can be misleading, this is quite a nice looking car with nice paintwork and upholstery. Perhaps one factor against the car is the lack of an engineer's certificate - naturally getting hold of one of those can be a frustrating and time consuming exercise - and costly. Regards Styria
A bugbear certainly but once you've done one or two its not as daunting.
$600 in Vic got me an inspection and what the guy told me when I booked it was that he will check for welds and structural engineering no no's.
He picked on one weld and factory spot welds, I paid him to fix the welds and seam weld the spot welded area and he passed the car after which I went to Vic roads and presented the engineers ticket, the roadworthy and has the numbers checked by staff.
all up under $1000, just.
Always better to consult an engineer BEFORE you start work & especially before spending any money. Otherwise it's likely you'll have to do everything twice... unless you're a perfectionist like me!!! :D:D
motec 6.9 W116 Convertible Mercedes W116 14
B FS: 300SD W116 1978 in AUSTRALIA Gumtree/eBay/Facebook Listings 0
