1973 350SE Progress....
More threads by zej
zej
Aficionado
Melbourne, Australia
All caused by a little patch of corrosion within the vent at the base of the windscreen....
Those inner guards are perhaps the biggest issue with the W116 chassis. Drains far too small which are then coated and often blocked by body deadener. Well done on getting the mess fixed! Tail lights & the firewall mat can also hide nasty surprises. If the tail lights are leaking take them out completely, clean thoroughly, replace seals if you can get any then reseal with a non hardening sealant (NOT silicone).
zej
zej
Aficionado
Thankfully the boot floor is solid, and the tail lights have been very heavy-handedly sealed up at some stage. I was going to re-seal them a bit more neatly in clear silicone before reading your advice! Would you use something like permatex gasket sealant?
I just found the fuel filler drain completely blocked as well... may have dodged another bullet there.
If you use any type of hardening sealant (including semi hardening silicone), you’ll find the only way to remove the tail lights in the future is to smash them out… I’m purchasing a product from Wurth for the job so I’ll let you know which one soon. Non hardening for windscreens & rubber seals.
Yes common for the filler drain to block up & rust the rear quarter & fuel door. As with all the small drains, make sure they’re free of debris.
Styria 1973 Stutz Blackhawk Websites and Links 2
Fotografa 1973 450SL for sale Gumtree/eBay/Facebook Listings 3
G Converting Speedometer on 1973 350 SE Interiors 4
G Centre Console of 1973 350 SE Interiors 8
G chassis no. on 1973 350E Exteriors and Body Repairs 5
G For Sale 1973 450se Gumtree/eBay/Facebook Listings 3
Phantom 1973 CE Coupe Gumtree/eBay/Facebook Listings 5
zej 350SE finally registered and on the road again Mercedes W116 10
s class 350SE trans failure Mechanicals 11
motec 6.9 Time warp 350SE 70000km Gumtree/eBay/Facebook Listings 5
motec 6.9 Nice 350SE on eBay Gumtree/eBay/Facebook Listings 3
SELfor50 FS: 350SE W116 - On All classifieds Gumtree/eBay/Facebook Listings 0
450SE 280SE & 350SE for sale Gumtree/eBay/Facebook Listings 10
116Benz Ebay 350SE silver/red Gumtree/eBay/Facebook Listings 7
Andrew280SEL Update on my 280SEL and 350SE Mercedes W116 6
Michel Reasonnable 350SE in Queensland Gumtree/eBay/Facebook Listings 4
B For 107 fans 350SLC manual - pity its not a 350SE.. Gumtree/eBay/Facebook Listings 7
B WTB: Instrument cluster 350SE (or just the speedo) Gumtree/eBay/Facebook Listings 2
S Progress Technical Information 3
mercdz MERCAR - Work in progress Exteriors and Body Repairs 11
Michel Another 450SEL... Work in Progress Mercedes W116 34
Oversize Progress.... Mercedes W116 202
L 280SEL for sale by the Maitland Progress Association Gumtree/eBay/Facebook Listings 1
TJ 450 Progress on 6.9 Mechanicals 2
s class bodywork progress on the W124 AMG3.6 Talking Torque 7
s class Progress on the 300TE AMG3.6 Talking Torque 8
L 6.9 Progress Exteriors and Body Repairs 2
Des Progress on my 280CE Talking Torque 19
s class This weekend's progress on trusty rusty Mechanicals 15
