W116 Instrument Clusters
So I took a few pics while I was fixing Blue Flame's instrument cluster.... Yes they're all dirty, but they hadn't been cleaned when the pics were taken. Note the differences:
The one that came out (incorrect speedo):
The special Euro one I bought (170MPH very hard to find):
Spare 450SEL?
Spare 280SEL?
I noticed that all had dates stamped on the back, which helps ID the year of the vehicle:
Oh and if you're wondering what the blank window is for... hold your breath no longer!
Column shifts!!
http://www.peachparts.com/shopforum...happened-all-w116-73-80-450-sels-mvc-625s.jpg
Which BTW can be converted into additional warning lights.... :cool::)
http://gallery.w116.org/dl/31369-2/Warning+lights+at+night+time.jpg
Very interesting Mark now if you put the face of the 280 tachometer onto one of your 6.9 clusters that would confuse the c@#%p out of the experts at shows. :D
LOL! I was thinking along similar lines! But I chickened out and stuck with the 5250 one
My Euro has 5000 tacho . But as has been talked about before there is no apparent reason for this or difference in rev cutout. :)
I'm sure it'd go a bit harder! ;):D
5900 revs are my guess which I am sure is a lot higher than factory cutout. :eek: Enlarge image that was the revs my car went to on 230.1 dyno run.
Are you using a standard 6.9 rotor or something else?
Don't know Mark haven't changed a thing in that regards. But when you boot it in first it hits 5500RPM before upshifting which I though was very strange . Then as I said compression has been checked its over 170 each cylinder . And corrected horsepower on dyno run was 288.9hp almost 3 over brand new Euro output. And exhaust was 1 7/8th inches each pipe on that run. :eek:
Might pay to check it so you don't over-rev the thing.... You may not have a limiter fitted.
BTW there's no way my dodgy bipass would work since the spark will still follow the least resistance to earth. And the spring was still functioning.... A heavier spring would increase the limit.
Possible I asked about revs on dyno run they said rev limit cut in at were it ends on rev graph. So may have to investigate more.
Funny how many of my cars hit around 270K km when they fell into disrepair and were neglected badly by their POs
Yes it appears to be a common mileage . 263k was on the odometer of my old 6.9 when I killed it. :eek:
And yet they'll last far longer if you actually care for them.... :mad:
Trust me its a lesson I have learned the hard way. This one is now in good hands as I intend to spend the time and effort to return her to her glory . :D:D:D
Typo alert: "here" = her! :D
Fixed happy now. :p:p:p waiting for coffee kick.
Geoff, I have lost track of your progress on the 6.9. I am sure there must be an update somewhere but I have been quite slack for a considerable period of time as far as posting is concerned. Perhaps you may provide members with an update. BTW, what do you think of TK's new layout and features ? Would be interested in your opinion.
Mark, how about you and your 6.9s ? Any progress ? I know that you have sold a couple (one to Darwin I believe), and you seem to be concentrating more so on the W126s. As a matter of interest, have you ever carried out any work on the 420SEL I used to own. Would love to get an update. Regards Styria
K W116 Instrument Cluster Gumtree/eBay/Facebook Listings 0
B FS: W116 instrument cluster rubber band - holds binnacle in Gumtree/eBay/Facebook Listings 1
