W116 blower motor series resistor
More threads by Jimb
Jimb
Distinguished
Kanahooka
Hello from Jimb sorry to bother you. Just obtained this 1974 W116 280SE on Easter Monday. So here am I on your forum .It is a nice car but has some electrical issues .My background is electrical / electronics so I am hoping I can cope with it's problems. Can someone please tell me where the blower motor series resistor is and how do I remove it for repair. Also how do I remove the blower motor for repair. The problem is this ,I replaced missing fuse 8 amp fuse 3. Supposing I switched fan speed to position 1 or 2 .Speed is actually not relevant .It runs for a short time then goes into full speed by itself and cannot be switched off unless I turn the ignition of. If the ignition is turned on again fuse 3 blows because the fan is drawing full current on high speed. If I disconnect the battery the system resets itself. You can then reselect speed one or 2 and it again after about 10 seconds switches itself back to full speed. I had a spare selector switch which I replaced and it does the same thing.I also removed electrical connections from thermostat. I suspect maybe 2 faults one is the series resistor and 2 the fan motor may be drawing a bit too much current. I measured the current at 7.6 amps on full speed which is too close to the rating of fuse 3 which is rated at 8 amps .Any help will be greatly appreciated.kind regards.Jimb
J
Jimb
Distinguished
Kanahooka
Hello Bryce.
That is very helpfull .
I am hoping the series resistors will be close by.
Regards Jim.
