Last one, I promise
One of the oil leaks came from the area circled in red here:
There's a ~1 inch black soft rubber hose that runs from the RHS rocker cover to somewhere. Attached (previously unattached) is a tiny (4mm o.d.), probably vacuum line. Oil was leaking through the hole where the line was supposed to be.
What's the big hose for, and is the small hose indeed a vacuum line that draws oil through it, and if so to where?
Theory was that in the absence of the vacuum line, oil under slight pressure was coming out there and leaking down the back of the block and towards the inspection lamp of the RWC people.
Ta
Ta
