Rubber Seals, Tail Light Lense and Headlight Wipers
More threads by Lukas
Hi all,
After the following bits - got a quote from MBSpares, but half are not available and the other half are pricey. Have yet to check AutoHausAZ, will do that too. If anyone has any of these going, please advise.
Thanks
1) LH rear tail light lense
2) LH + RH rear tail light foam seals / surrounds (the thick ones that
goes between the light lense, the light "frame" and the car body all at
once)
3) Rubber seal for centre rear chrome moulding (the one that contains
the boot lock + button)
4) 2x rubber seals for rear number plate lights
5) 2x headlight wiper assemply - wiper arms
Yes, you are after some pricey bits. It varies from country to country, but expect to pay $100 per side for the tail light rubbers. I recently bought one headlight wiper arm - again it was about $100 from memory.
The tail light lenses are even more expensive.
Lukas, I can probably help you out with nearly all of your list mate..
Give me a bell tomoz, if you get voicemail just leave a message with your number and i'll call you back.
Cam. :)
OK the prices I quoted were for new items. I dunno why, but I just assumed you were after new parts.
Hi Lukas, unfortunately you're after some pretty pricey bits, especially when buying new in OZ country. S-Class' quoted prices are in fact, very reasonable. See how you go with Cam2 in your capital city - whatever he can't help you with, let me know. Regards Styria
L
Thanks for that folks - for a lot of the stuff I assume new is the only option because all of the 2nd hand stuff would be perished foam / rubber (like mine is).
I was quoted $113 each for the tail light foam seals (which would seem to be a good price), and the wiper ares are $105 (right) or $151 (left) - bizarre that the side changes the price. Maybe all the Germans keep crashing into each other on their drivers side, so those ones cost more.....
Turns out AutoHausAZ have even less than MBSpares in this area, although admittedly Mercs are not realy their specialty.
Styria: Thanks - am talking to Cam, will let you know if I'm still after more bits after that.
Reposted here for Motec:
Hi Mark you asked about seal availability the answer is yes.Prices i was given are tail lght seals $112 each,Headlight to body seal $122 each,Headlight lens seal $45 each. Now as i said Steering damper was $48, Intake gaskets to fit my throttle body were $29 each, Front window seal $110,Rear window $165, Boot rubber $231, All 4door seals $1100. Every one of these prices beat the US price.
What's MB Spares number??
Ha Ha you beat me to it thanks Mark. oh by the way less than 20 post to go. :D
I am getting some water into the boot of my SLC.
I was able to get 107-826-02-58, for $67 USD (before tax/shipping), but 01-58 for the other side is NLA. You can get one from URO parts but from what I gather these parts are so bad they are not worth bothering with.
Hi Byrce check rear window seal and overflow hose in fuel portal. The rubber hose runs through boot to underneath rubber hardens and it parts way from connection allowing water into boot
Near perfect condition, but old parted out tail light assemblies are easier to source than new foam rubber seals.
An easy problem solved, but only at the high cost of new seals, which can serve near perfect, but old parted out tail light assemblies.
I have been there done that, with a 6.9 and a W202.
In the case of the 6.9, the complete parted out R.H. tail light assembly cost cost me $35, but the cost of the new seal was triple the price a the time. The old seal went back in.
Not a problem with the 6.9. as with most venerable old cars; I avoided driving it rainy weather.
The existing seal in the W202 was quite OK, as was re used. Still a go anywhere, anytime car, but I have noticed that the wiring to the headlights is starting to look quite tatty.
That problem will be addressed at the time when one of the halogen headlights blow, then I will replace all four bulbs with new LED bulbs at around $100 each.
QLD6point9 HPF rubber boots, height rod retrofit and faults encountered Mechanicals 5
T FS: Rubber boots for self leveling valves 6.9 Gumtree/eBay/Facebook Listings 0
WGB Last pieces of rubber between bum and road Exteriors and Body Repairs 16
J W116 windscreen rubber on eBay Gumtree/eBay/Facebook Listings 0
B FS: W116 instrument cluster rubber band - holds binnacle in Gumtree/eBay/Facebook Listings 1
abl567 Rubber Mounts and Bushes Mercedes W108 and W109 14
BenzLover Delivery vale seals on my IP Mechanicals 2
Oversize Windscreens and Seals Exteriors and Body Repairs 11
TJ 450 Sunroof frame seals Exteriors and Body Repairs 5
L Sump Seals Mechanicals 2
Michel Taillight Seals for 116 Exteriors and Body Repairs 9
motec 6.9 1931 8 litre Bentley Boat Tail. Talking Torque 3
260ebenz Tail pipes Exteriors and Body Repairs 16
motec 6.9 Never tail gate a 6.9 Mercedes W116 12
