ML 500 for Michel in N.S.W
More threads by motec 6.9
Having owned an ML320 Diesel and an ML 500 I can say that around town there is nothing much in it except fuel consumption and more chance of maintenance issues with the diesel.
But get the ML 500 passing a road train on the open road and there is no competition as the ML 500 runs away and hides from a 320 at speed.
If you drive the ML 320 below 110 Km /hr it is easier on juice than the 500 but once the speeds get up they are level pegging by a 130 km/hr cruise speed. The diesel will be blowing black smoke and wheezing a bit while the 500 just finds it's pace.
ML 500 also has bigger brakes which last a bit longer and all 500's have airmatic which will probably get expensive to fix when the mileage gets up .
The 164 doesn't have the brake wear issues of the 163.
Having owns an ML320 Diesel and an ML 500 I can say that around town there is nothing much in it except fuel consumption and more chance of maintenance issues with the diesel.
I was hoping you would chip in.;)
For the amount of use the ML would get with me, I would not contemplate a diesel as the distances I would travel would not be great.
I was originally looking at an ML430, but have been dissuaded by a prominent MB service and spare person from considering it and was recommended a 500 (especially in view of my desire for a V8 power plant).
I am in the early stages of research and will be ready to purchase just after the new financial year (unless a great example turns up before that). :D
Hi Michel I would say Bill knows ML having owned both W163 & W164 2 off. And is waiting for a W165 . A work college owns a W164 ML63 has done 82000km in it since purchase in 2010 . He has stated it has been a lot better than his previous ML55. He is apparently going to get new ML63 in new year. :) And having heard it go down the road wow does it go for a truck. :D
Ah but it would be to me with my brood of hounds. I hear though that the air suspension can be an expensive nightmare when it needs work done.
If it's anything like the W220 (S Class) they you would prob need an additional mortgage :eek:
There are cheaper options ask Ant . There's a few companies doing rebuilt exchanges on the struts I believe Craig S knows about them as well . Will post them if you are interested once I get near my computer.
It depends whether you get a W163 or W164 500.
The 3 valve 5 litre motor is bulletproof so long as it is serviced and so is the 5.5 litre in the W164.
Having driven behind both motors for a very long time I can say that in normal driving there is not much to notice that is different unless you really give the 5.5 it's head then the extra HP is noticeable.
The lifetime fuel consumption was 14.5 litres/100km in my ML 500 and about 12.2 L/100 km in my recently sold E500 - weight would probably make more difference to the figure than the engine.
On a trip the ML 500 would drop to about 11 L/100km with the occasional dip to 10 l/100km while motor way cruising whereas the E500 would do 10 L/100km and dip to 9 L/100km - I once saw 8.8 l/100km on a 2 hour motorway cruise at 110km/hr.
I cannot remember a single repair required on my ML 500 and the only repair I had on my E500 was the mousewheel for the comand breaking it's shaft a few months ago - but even that is a $1,000 + experience.
The Diesel had a problem with the cold start Glow plug relay which was never fixed under warranty - although two sets of glow plugs were replaced at M-B's expense. It was finally fixed at my expense for $1700 which is the cost of a new relay and replacement of 6 Glow plugs. I also had the electric fan fail after warranty had expired and that was a $2400 experience.
Other than that you are looking at the total repairs as opposed to maintenance costs of three cars totalling nearly 300,000 km.
The 163 ML270 CDEI was quite reliable but needed new rear brake pads every 18,000 km which was crazy considering it only needed it's oil changed every 28,000 km. I kept a set of genuine pads at home and changed them myself every time the light came on.
Cheers
Still a lot more expensive than springs that never wear out :roll eyes:
Give me an ML350 W164 with standard suspension any day, Oh and the ride is better as well. :)
Actually those prices don't seem too bad.
Not that greatly different to a set of Bilsteins on a sprung chassis.
I have mentioned the cost at the agent and they talk about $5,000 per corner but I think the rear subframe has to be dropped to remove the rear air springs.
I do agree that a well set up sprung chassis gives a smoother ride than air but there are advantages in changeable ride height and stability under varying loads that a sprung suspension can't deliver.
Thank you Motec.
I'm very aware of these cars.
I scan eBay, Carsales and gumtree.
I'm hoping members of this esteemed forum might know of something going down privately!
Hi Michel unfortunately I am currently in Bogan central so I don't have contact with anyone owning a ML so unless I see it on carpoint or another sales site sorry cant help. But I did find cheaper struts. :D
motec 6.9 Clk 500 Gumtree/eBay/Facebook Listings 6
motec 6.9 1934 Mercedes 500 K tourer Talking Torque 11
Styria Fiat Abarth 500 Websites and Links 13
260ebenz $16,500 1982 300d Gumtree/eBay/Facebook Listings 6
motec 6.9 Corvair for Michel Talking Torque 0
motec 6.9 190E 2.6 for Michel Gumtree/eBay/Facebook Listings 24
motec 6.9 780 cu Cobra for Michel Talking Torque 10
motec 6.9 E55 for Michel Gumtree/eBay/Facebook Listings 16
motec 6.9 S430 for Michel Gumtree/eBay/Facebook Listings 6
motec 6.9 E430 for Michel Gumtree/eBay/Facebook Listings 41
260ebenz Michel's 450SEL Mercedes W116 5
motec 6.9 AMG rocker covers for Michel Gumtree/eBay/Facebook Listings 8
Oversize SLCs for Michel Gumtree/eBay/Facebook Listings 2
motec 6.9 Corniche for Michel Gumtree/eBay/Facebook Listings 1
motec 6.9 Just the car for Michel Gumtree/eBay/Facebook Listings 83
motec 6.9 SLC's for Michel Gumtree/eBay/Facebook Listings 1
motec 6.9 Corniche on ebay for Michel Gumtree/eBay/Facebook Listings 3
motec 6.9 27 litre Bentley for Michel and Brian Talking Torque 8
motec 6.9 Project for Michel Gumtree/eBay/Facebook Listings 17
motec 6.9 A Brabus for Michel Gumtree/eBay/Facebook Listings 9
motec 6.9 Corniche on ebay for Michel Gumtree/eBay/Facebook Listings 2
motec 6.9 SEC for Michel Gumtree/eBay/Facebook Listings 4
motec 6.9 Stutz for Michel Gumtree/eBay/Facebook Listings 6
motec 6.9 For Michel Gumtree/eBay/Facebook Listings 4
motec 6.9 Wheels for Michel Talking Torque 5
motec 6.9 Cadilac Man for Michel Talking Torque 2
motec 6.9 1954 Silver Dawn for Michel Talking Torque 4
motec 6.9 For Michel & Benzboy Gumtree/eBay/Facebook Listings 3
Des For Michel Gumtree/eBay/Facebook Listings 5
SELfor50 Yet another option for Michel Gumtree/eBay/Facebook Listings 11
SELfor50 Michel's New Team W116 RACE CAR Gumtree/eBay/Facebook Listings 26
SELfor50 A 2door for Michel Gumtree/eBay/Facebook Listings 9
G One for Michel? Or Delilah? Gumtree/eBay/Facebook Listings 3
G A Challenge For Des & Michel! Mercedes W116 18
Des Michel Talking Torque 3
Des Michel needs one of these for his Office Talking Torque 6
Des A tour of Michel's Garage Talking Torque 2
Des Question(s) for BenzBoy and Michel Talking Torque 12
Des Michel Mercedes W116 17
Des I could see Michel in these, hot rod coupe Talking Torque 4
Des Michel's warehouse Talking Torque 11
