Yrs I think there's plenty of BS flying around regarding outputs! It really makes me wonder about some of these (Wiki):
GM 6.2-litre Supercharged V8 LSA[edit]
Power: 430 kW (585 PS; 577 hp) @ 6000rpm.
Torque: 740 N·m (550 lb·ft) @ 4200rpm.
The supercharged 6.2L LSA is similar to the LS9 and debuted in the 2009 CTS-V. The LSA has been SAE certified at 556 bhp (415 kW) at 6100 rpm and 551 lb·ft (747 N·m) at 3800 rpm. GM labels it "the most powerful ever offered in Cadillac’s nearly 106-year history". The LSA features a smaller 1.9L capacity supercharger rather than the 2.3 L variant of the LS9. Other differences include a slightly lower 9.0:1 compression ratio, single unit heat exchanger and cast pistons. A 580 bhp (430 kW) and 556 lb·ft (754 N·m) version of the LSA engine is used in the 2012 Camaro ZL1. On 26 April 2013, Holden Special Vehicles announced that this version of the LSA engine will also be used in the GEN-F GTS.
GM 7.0-litre V8 LS7[edit]
Power: 375 kW (510 PS; 503 hp) (W427)
Torque: 640 N·m (470 lbf·ft) (W427)
This engine was originally used in the Corvette Z06 that was then shipped over for usage in the W427. It made its first appearance in Australia in 2008. The W427 was designed and built to celebrate the 20th anniversary of HSV.
GM 6.2-litre V8 LS3[edit]
Power: 317 kW (431 PS; 425 hp) (E Series), 325 kW (442 PS; 436 hp) (E Series II GTS), 340 kW (462 PS, 456 hp) (GEN-F SV Enhanced models)
Torque: 550 N·m (410 lb·ft) (E Series), 570 Nm (420 lb ft) (GEN-F SV Enhanced models)
This engine debuted in the E Series. It is a GM built LS3 V8 customized for HSV's usage. The transition from LS2 to LS3 was primarily to meet impending Euro IV emissions requirements being introduced in Australia on 1 January 2009 and to compete against 2008's 315 kW (428 PS; 422 hp) FPV GT.
GM 6.0-litre V8 LS2[edit]
Power: 297 kW (404 PS; 398 hp) @ 6000 rpm(Z series), 307 kW (417 PS; 412 hp) (E Series)
Torque: 530 N·m (390 lb·ft) @ 4400 rpm (Z series), 550 N·m (410 lb·ft) (E Series)
This engine debuted in the Z series. It is a GM built LS2 V8 customized for HSV's usage. One of the main reasons that this engine was used is that the LS1 V8 does not meet ADR 79/01 (Euro III) emissions regulations. This new engine also has connections to the L76 6.0 Litre used in the VZ and VE Holden Commodores.
GM 5.7-litre V8 LS1[edit]
Power: 250 kW (340 PS; 335 hp) (VTII), 255 kW (347 PS; 342 hp) (VX), 260 kW (354 PS; 349 hp) (Y series), 270 kW (367 PS; 362 hp) (AWD models), 285 kW (387 PS; 382 hp) (YII series)
Torque: 473 N·m (349 lb·ft) (VTII), 475 N·m (350 lb·ft) (VX),475 N·m (350 lb·ft) (Y series), 510 N·m (380 lb·ft) (YII series)
This motor started its debut in the VTII series of HSV sedans. It produced 250 kW (340 PS; 335 hp) of power – 30 kW (41 PS; 40 hp) more than HSV's previous "Stroker" 5.7 V8 used in the VT. It was a slightly de-tuned version, with 7 kW (10 PS; 9 hp) less than when it was in the two-door sports body of the Corvette. Continuous modifications were made to the LS1 engine throughout its lifetime, reaching 285 kW (387 PS; 382 hp) in the YII series, just 15 kW (20 PS; 20 hp) under the 300 kW (408 PS; 402 hp) GTS. AWD models such as the Coupé4 retained a similar configuration to other YII series models but were fitted with a more restrictive exhaust system, reducing power to 270 kW (367 PS; 362 hp). The LS1 was phased out for the new 6.0 litre LS2 in the Z Series. However, it was still used in the AWD models of the Z series.
GM 5.7-litre V8 LS1 (C4B)[edit]
Power: 300 kW (408 PS; 402 hp) @ 6000 rpm*Torque: 510 N·m (380 lb·ft) @ 4800 rpm A modified version of the LS1 enhanced by Callaway Cars Incorporated, this engine was used on the VTII, VX and Y series of GTS models as well as the SV300. Differences from the LS1 included ported cylinder heads, larger throttle body, revised camshaft, remapped ECU, titanium valve spring retainers, upgraded valve springs and valves. The compression ratio was also lowered slightly to 9.95:1 and the engine ran MAFless. In HSV models, this engine was used with a higher than standard 3.91:1 final drive ratio.
HSV 5.7-litre '350ci Harrop Stroker' V8[edit]
Power: 215 kW (292 PS; 288 hp) @ 4800 rpm (VR-VS), 220 kW (299 PS; 295 hp) (VT)
Torque: 475 N·m (350 lb·ft) @ 3600 rpm This motor had its debut in the VR series of HSV sedans. It was a bored and stroked version of the Holden 304ci 5.0 litre and was originally available on the VR Senator and GTS 215i. A Tremec T-56 six-speed manual gearbox option exclusive to this engine was introduced as the then current Borg-Warner T-5 5-speed could not reliably handle the prodigious amounts of torque it produced. The HSV VS GTS-R had the blueprint option to produce more power at around 230 kW (313 PS; 308 hp). The 215i engine was also available on the Grange long-wheelbase model. Its last appearance was in the VT GTS(Series 1). The LS1 replaced it in the VTII series.
Holden 5.0-litre V8[edit]
Power: 180 kW (245 PS; 241 hp) @ 5200 rpm (VL),165 kW (224 PS; 221 hp) (VN SS) 215 kW (292 PS; 288 hp) (VN Group A SS), 200 kW (272 PS; 268 hp) (VP), 180 kW (245 PS; 241 hp) @ 4800 rpm (VN-VP), 185 kW (252 PS; 248 hp) (VR-VS), 195 kW (265 PS; 261 hp) (VT)
Torque: 380 N·m (280 lb·ft) @ 4000 rpm(VL), 411 N·m (303 lb·ft) (VN Group A SS), 410 N·m (300 lb·ft) @ 3600 rpm (VN-VP), 400 N·m (300 lb·ft) @ 3600 rpm (VN-VS), 430 N·m (320 lb·ft) @ 3600 rpm (VT)
This engine for HSV was available in 2 guises. The twin throttle bodied versions designed for racing use were available in the VL and VN Group A cars from 1988 and 1990 respectively. For the majority of HSV sedans using this capacity motor, the engines were modified versions of the standard EFI Holden V8. Note that there was also a VP equipped Clubsport 5000i that used the remaining 4 bolt main Group A blocks with SV5000 red motor ancillaries. The LS1 replaced it in the VTII series.
Additionally:
1. A non-EFI version was fitted to the VL Calais SV88, producing 136 kW (185 PS; 182 hp) @ 4400 rpm and 355 N·m (262 lb·ft) @ 3200 rpm.
2. The VL SS Group A SV Commodore was the first Holden V8 to feature Electronic Fuel Injection.
