6.9 cold start issue
More threads by QLD6point9
QLD6point9
Distinguished
Rockhampton QLD Australia
Hey there guys and girls,
Just hoping for perhaps an easy answer here as opposed to diving back into the Bosch Kjet diagnosis manual (having been through the process before).
Story is, 6.9 that I own has all of a sudden (after previously working perfectly) presented with an issue whereby cold starts are not possible (cranks but doesn't start) unless you disconnect the fuel pump safety switch (blue plug on the fuel distributor housing) - see photo attached. (note: as described, if I do disconnect the blue fuel pump safety plug, the vehicles fuel pump will audibly be heard pumping fuel and the vehicle will start normally).
Recently, all k jet components had been refurbished by a Kjet specialist (auxiliary air valve, fuel distributor and Warm up regulator). New injectors have been installed, new fuel pump and new filter in the tank and also new inline filter.
I've got an exhaust probe that measures AFR (air fuel ratio) and I had previously tuned the fuel system to achieve almost perfect AFR results and had no issues with the vehicle for quite a good while (started first time every time).
The only items that haven't been replaced are the cold start injector and the accumulator.
I am wondering if this sounds like accumulator type troubles. Either way, it sounds like I am going to have to hookup the pressure test gauge and do some tests from the Bosch diagnosis manual.
I did however want to check firstly if anyone else has experienced this cold start issue, and whether it was for instance an accumulator issue.
It seems almost like a tired accumulator has decided to give up the game after perhaps 45+ years.... And or, I may have more debris blocking optimal fuel pressure delivery which I may need to also tend to (despite having previously replaced and cleaned all filters and gauze filters - including in tank filter).
Any and all suggestions welcome
Cheers James
BenzBoy How to start yr Benz on a cold morning... Articles 22
B Rough running when cold (6.9) Mercedes W116 1
s class Cold Galvanization Mechanicals 4
S Stop/Start Articles 0
Michel Hard to start Mechanicals 15
Oversize Did this start the 6.9 Legend? Articles 0
S Stop/ start Technical Information 3
mathew M116 won't start Mercedes W126 58
s class Don't start investigating if you don't want to find problems Talking Torque 4
L Preparing to Start a Car that Hasn't run for ~4 Years Mechanicals 12
Styria Winding Road Issue 1 - Internet Talking Torque 1
260ebenz March issue Talking Torque 1
260ebenz MB Enthusiast November issue Talking Torque 0
260ebenz Star Torque- Summer issue Talking Torque 0
260ebenz Highlights Nov issue- MB Enthusiast Articles 0
260ebenz September issue- MB Enthusiast Articles 0
260ebenz March issue- MB Enthusiast Articles 5
260ebenz November issue- MB Enthusiast magazine Articles 10
