Can you see a pattern here?
Okay, so I pulled the starter apart, cleaned it and re-greased the greasy bits. Everything seems in order mechanically and there is plenty of life left in the brushes.
Come re-assembly time, the question arises: how do I "restrain" the 4 brushes so I can re-insert the rotor?
The 4 stator coils are attached via large and shallow (and very tight) individual screws to the starter's housing, and the end cap seems to be an interference fit (also very tight) over the end of the housing. This means that there is no access to the brushes end of the assembly, and thus no way to pull the brushes back while re-inserting the rotor. As I see it, options are:
Even contemplated drilling small holes in the sides of the end cap, to pass wire / zip ties through to restrain the brushes, but then you have holes in your starter to patch.
Suggestions please, especially if it's a "known good" method. Have photos, but different computer sorry.
Ta
- If I could remove the 4 stator screws (I've tried, even made a custom screwdriver bit - no luck), I think the whole assembly will come out, brushes and all. Once the rotor is inserted, getting the whole lot back in will be tricky, but should be do-able.
- If I could prise the end cap off, there would also be ample access, and no tricky re-insertion.
- Some sort of tricky thing with a ring of wire holding the brushes back: insert rotor, pull wire out.....
Ta
