Predictably, I've been playing with this after I pulled it out in preparation for turning the engine. Observations:
Anyone know if this is how it should be? The fan operates fine while the vehicle is idling, can't say for when warmed up or under load.
The fan was quite greasy after I pulled it out, so it hit it with the pressure cleaner. Subsequently noticed (weeks later) that it was dribbling a little fluid, so (thinking that water had gotten in) pulled the little circular metal disc off to reveal a bearing race and some goop. Cannot get the allen bolts off the back of the clutch loose at all (dissimiliar metals = very rusty); so can't pull it apart completely.
Does anyone have any experience in cleaning the innards out (including or excluding the viscous clutch itself)? I am tending towards "it works, leave it alone you idiot".
Ta
- The clutch is initially quite stiff, but you can turn the fan independently of the clutch with a little effort
- If you do turn the fan independently of the clutch, the clutch frees right up
- Leave it for a while and you're back to square 1
Ta
