G
GreaseMonkey
OK, my reply above was in response to WGB, I posted at the same time as Oscar, but it was not a reply to him.
Re Oscar's remarks;
gravity will work if all you are doing is changing fluid, NOT if there is air trapped.
If you imagine an air bubble in a tangle of bent pipes, it will sit at the highest point, right?
Well the brake fluid can pass below it to the bleed nipple without it moving, so leaving what may feel a better pedal because of the new fluid, but still not 100%.
Regarding DOT numbers, I don't know the specs on DOT 5, but I do know there was an industry wide warning about DOT 4 not being compatible with some recent Japanese seals and could lead to failure in Toyotas.
Yeah, great, let's put DOT 4 in every Toyota we see, sooner they're off the road the better.
Chris
Re Oscar's remarks;
Chris
