Having had a couple of queries on the subject
.........To set up any make of Auto Transmissions it is imperative that, firstly the Engine is in a good state of tune and in good condition, not with low compression. An Engine and an Automatic Box should be matching bed fellows ! With vacuum modulator pressure control units the vacuum reading at the modulator end must be the same as manifold reading. Say 16 to 18 inches and the pressure reading should flick up and down with a blipping throttle. This tells that the internal valves are not sticking. Most low vacuum reading are down to retarded ignitions, for what ever reason. Fix it ! A slow modulator reaction will never fix a problem. A weak modulator spring can be checked using a kitchen scale to read Lbs pressure before breaking. But when in doubt .just fit a new one. They work hard, in and out like a fiddlers elbow !
For instance in G M Cars, with non adjustable modulators and a hollow rod, just put a brake rivet down the inside to raise the pressure, works wonders at times.
Mercedes Modulators are like Hinz's Beans.. they come in 52 varieties. Fortunately they are easily adjustable and respond well to a full turn on the adjuster to fix mild flares., if you are lucky. But the vacuum must be right !
Any questions I will be happy to address,
if I can.
