white plugs
Add this to the list of things I don't understand........plugs by Bosch always darkish Grey. Changed them to NGks after a trip to Cootamundra a week ago. Same petrol from Cowra
Then a couple of shortish runs to the Shops , plugs are now white on the electrodes ( black around the body ) Needed a slight tweak to richer and also to the faster idle speed ( about 50 + revs ). The Bosch Plugs were still good but had a few miles on them. ????????.
.............Sean
.............Sean
I'd say they turned white after the long run and starting to darken after the short runs, sounds normal to me.
No ,the other way round Helmet, grey always ( with Bosch ) including after the trip to Cootamundra. But white after the change to NGKs and after two short runs to the Shops. ....I agree it should be dark around the City and whitish on a long hot run. .... Sean
P.S. I'm trying desperately to avoid opening the engine re the valve stem seals. With an 85% thermostat the Temp. from Cootamundra via Cowra was running at 90% driving in the 3 to 5000 range. I have now fitted a 71 % thermostat and sticking to the speed limits ! The Radiator keeps the Temp to the high seventies. Time will tell.......
Maybe I need a colder plug. I used the NGK equivalent from the chart. An old Post suggested that I should have gone one number colder with NGKs ????
Sean
Ricord
Of course, you need colder plug, it pretty much is a must for your situation. Good luck
Well it seems that the printed Chart for equivalent NGK from Bosch is wrong. The no 5 is to hot and should be a colder no. 6. .. NGK's own web site recommends no 6 for a 280 SL 107. I'll pull a plug again to be sure and fit the correct plugs........Sean
The sixes have it ! ! the difference between 5s and 6s is night and day. Now a light grey instead of a stark white.
I guess it is easier to correct a wrong item on a web page compared to a print run of thousands of Charts.........Sean
S Painting a Bumper and Boot Lid Artic White no damage just Paint Idea of cost Exteriors and Body Repairs 14
braminator123 280S - white over green - 140000km Gumtree/eBay/Facebook Listings 3
6.9forever 300SEL6.3 in white for sale - no connection to seller Websites and Links 19
Oversize White 560SEL Wreck Mercedes W126 33
Oversize The White Whale (3686) Mercedes W116 34
BenzBoy White Magic Exteriors and Body Repairs 6
Oversize White 450SLC for sale Gumtree/eBay/Facebook Listings 5
Oversize White 6.9 for sale in Sydney Gumtree/eBay/Facebook Listings 16
sergeich77 280s papyrus white Mercedes W116 12
Michel Two Ordinary Cars (Brown and White) Talking Torque 32
Nütz Just how rare is white MB tex? Interiors 30
SELfor50 White (wedding) 6.9 Gumtree/eBay/Facebook Listings 2
S Better Plugs Articles 4
S Iridium Plugs Articles 14
I Correct spark plugs and dizzy cap...??? Can’t find online Mechanicals 3
Oversize Bosch Non-resistor plugs NLA? Mechanicals 0
Styria Fouled Spark Plugs Technical Information 1
BenzBoy Spark plugs? Mechanicals 8
BenzBoy Refresher course in reading spark plugs. Mechanicals 1
BenzLover Glow plugs Mechanicals 4
WGB Plugs and Gaps Mechanicals 3
