It's getting confusing, but if I can follow the flow. You have a car which originally had a 250 Iron block motor and 4 speed manual. Now you want to drop in the 560 alloy block motor and find a suitable gearbox.
Two choices. Uprate the clutchplate on the 350 gearbox and bolt it on, or get a 5 speed auto box that would have been with the 560.
Don't mess around with the rear end or else you'll need to start investigating final drive ratios and change the speedo.
From my recollection, the gearboxes had same moutnings for the 350 / 450 iron block and the subsequent 380 / 420 / 560 alloy blocks.
Differences between the 350 and 450 were all related to lengenthing the stroke of the motor to get extra displacement plus gains in power and torque [things like more fuel flow to accomodate extra need for vital juices].
When changing to the alloy motors you have to consider how to transplant the engine management systems and fuel systems [changing wiring looms etc].
