- Thread Starter
- #41
Are the injectors different for the different engines? (450-500-560)?
Yep, the 560 ones are different to the 450 ones. Much more expensive.
not sure when the change occured, if your 500 needs the same ones as the 560 or a 450.
Thanks Sean
I have not done the vac test, but when I went up to get my pink slip last week we put the car on the CO meter and adjusted the idle and the mixture screw and it is running really well.
Next thing to focus on is the tranmission shift points.
Even floored, the transmission shifts to the next gear at around 3500-3800 rpm. You can make it shift later with the gearstick though. But it won't kick down if RPM will end up over the values i mentioned.
From looking at the workshop manual, it looks like I have to adjust the control pressure rod, but I find the instructions rather cryptic. Anyone have experience with this?
Thanks, that would be good.That reminds me Bryce.
I need to dig out my uncle Neil’s (Fletcher) pic for you.
I've been using the 107 this weekend and I've noticed some sqeaking from the rear end that gets worse when the brakes are on.
After a longish drive (40 mins), the alloy wheels are HOT to the touch on the rears, but ok on the fronts. Both rears are hot, not just one.
My assumption here is that I have dragging brakes. If it was on one side it would be easy - start with the flexible hose and if not that, the caliper. However, with both sides, I'm not so sure.
There is also quite a bit of brake dust on the rears (more than the fronts!)
Now have all new hoses and also rear calipers. Brakes are now very good!My Money says the Flexible Hose is acting like a one way Valve
On the Clutch Hose of my MGA and on one front Brake on my '64 3.8 S Type Jaguar
Yes, it was a partial blockage in the A/C drain line. On a humid day there was not enough flow so eventually the evaporator case would fill up with water and leak out the top!Hi Bryce, lots of good work on your 450SLC.. Did you manage to rectify the water leak ? I am just not quite sure if I am following your threads correctly. Unfortunately, your backseat is typical of wear and collapse normally is found so readily in 6.9's, with horsehair disintegrating to dust,the calico under the leather just getting ripped apart by old age, but it can all be repaired and re-sewn. Regards. Styria
I don't know, but I am assuming a build up of dirt/dust.Insulating material, or built up dust/dirt Bryce?
