Those familiar with Kent Bergsma videos will appreciate that he is a hands on person, and he usually explains quite succinctly the procedures involved in carrying out various repair tasks. Take this latest video that I am submitting - all very well and good if your car is on a hoist as illustrated, but how about when you're on the open road, whether city or highway ? Then this task is not quite so simple. Anyway, first his procedure as hereunder:
https://www.youtube.com/watch?v=mmqmpmzl9y0
So, take the front first. You can only lift one side at a time by means of your tyre jack. Inserting that rubber/metal bung is not that straight forward _ Kent has only illustrated the insertion of one rubber - how about the second one ? Quite often, and rather easily, there is insufficient space to squeeze those rubbers into position - I know, because I have had to do those under more favourable circumstances rather than being stranded on the road. In addition, if there is no air in the system, it is well nigh impossible to insert the lifting part of the jack into the recess (hole) provided. That's just one side - you then need to tackle the other. Furthermore, with the road wheels still in place - try and get those rubbers into position.
At the rear, if your car is down, there is no way of inserting the supports from the inside as described by Kent. No, the wheels need to be removed before you can even think about inserting the supports. I have also found something quite peculiar at various times - with the suspension being right down, and endeavouring to lift the car by means of the car jack, the system does not allow the wheel to "hang down" - in other words, the suspension moves up with the body and even if one removes all wheel nuts, it can be almost impossible, in fact it is, to remove the road wheel from the hub past the edge of the rear guard. Similar sentiments apply to the front, but there is more clearance.
So, it can all be pretty tricky and, I guess in a round about sort of a way, just about impossible to get yourself going. As well, how many cars have those emergency rubber buffers ? I suspect this could be another issue.
Regards Styria
Regards Styria
