You're right, no jake brake
Well I've narrowed the problem down and almost got it back running properly yesterday.  Speaking of secondaries, the flaps above them are supposed to be closed at rest.   At the beginning of Stage II those flaps or air valves remain closed for a short time.  Of course a little air gets past but the vacuum created underneath sucks fuel through the bypass jets.  Then as the vacuum increases and air flow increases, the air vlaves open right up exposing the Stage II jets.  There's a vacuum dashpot connected to the shaft of the air valve.  It's job is to make the transition further moderated by controlling how slowly the air valve opens for full throttle.  So spring tension aside, without it, the air valve can open suddenly and fuel supply through jets is affected adversely.
This is pretty much what's happening with mine.  The spring tension had virtually gone for the stage II air valve.  Plus, the dashpot is leaking but always has.  Add to that, the air valve's shaft was stiff to move.  Lots of crap in the joins and bearings.
So when I go full throttle, the secondary air valve jumps open.  There's no vacuum below the air valve to suck fuel through the bypass jets to begin stage II let alone fuel coming through the stage II jets.  No fuel, no power.
So I should be able to retension this valve spring.  Easier said then done.  I can't find the sweetspot.  The manual's got a plan for a  custom test tool to calibrate the air valve.  I can't make it.  I'm also wondering whether I can get away with a dodgy dashpot.  The manual refers to stage jump without it, which I don't mind, but the second stage has to be operative.
I removed the inline fuel filter thinking it might be a restriction.  I couldn't find anywhere in manuals where the fuel filter is on these carby cars.  There's nothing in the back like the FI cars.  There's just the screen in the fuel tank and a pre filter in the Solex.
Pre filter in Solex
View of the Solex
What needs adjustment
Removing and cleaning the air valve componets made a big difference.  Before it would bind when moved.  It needs to be frictionless almost for an attempt at calibrating to be worthwhile.
