The reason why engine oil should be changed more, rather than less often, I figure, has little to do with the quality of the oil. It is suggested that a good quality oil should last 30,000 klm, and I see no reason to disagree with this.
It has more to do, I think, with pollution of the oil with combustion products. When fuel burns, it produces water vapour, carbon dioxide, carbon monoxide, oxides of nitrogen (the nitrogen combustion products partly derived from the nitrogen in the air), and sulphur products, although the sulphur should only be there in trace amounts.
Small amounts of water vapour go into suspension in the oil, although they are also liberated by heat as well. Carbon dioxide and carbon monoxide dissolved in water produces carbonic acid, oxides of nitrogen dissolved in water vapour produce nitrous and nitric acid, and sulphur products dissolved in water vapour will produce sulphurous and sulphuric acid. You also get free suspended carbon in the oil, which will turn oil black. I guess that it also leads to sludge build up.
All of these pollutants will build up over a period of time, but the rate of build up happens more quickly when the engine is below normal operating temperature, and the clearances are greater than what is normally designed for.
None of the above unfortunately, answers the problem posed at the start if this string. If you drive your car say only 1500 klm per year, and for fairly long distances when you do, the rate of pollutant build up should be less. I guess that comes down to the question: How much pollution do you tolerate in the oil?
That is, for me, the answer that I am seeking.
