B13 - I have seen your story referred to elsewhere - may even have been on TOPKLASSE as well, but am not sure. I have also seen a frontal photograph of your engine sump area, and it certainly seems to indicate that the engine in your race car has not been particularly well looked after. I hope your oil changes and flushing the engine will work, but I have my doubts. You may well find that it is tired - just general wear and tear. Please take no offence - to me, anyway, you may well have a major job on your hands.
At the price I've paid for it I bet it is tired old engine... when I bought it it only ran on 4 cylinders. Through intensive reading, testing, learning trial and error, help from TK and the other place, it now runs... well.. about as well as I could expect a V8 engine in an $800 mercedes to run... I've addressed each problem in a methodical manner and spent money where I've needed to. True to good design now that it does run right at least makes decent power, no knocking, tappets and chain are noisy (new chain/guides/sprockets time), and now that its had an oil flush treatment and Pennzoil high-milage oil put in, the smoking has gone away and the oil looks golden-brown as opposed to black. I congratulate myself on how far I've gotten with this engine, actually.
Its not going to win any races in its current form - nor is it going to blow up on the starting grid.
Getting back to the topic, so answer s-class question on oil grades, I'm no expert, and I wouldn't make a descision based on info just from me, but my experience is from 20 years of motor sports and owning mostly performance cars... also my sidekick (mechanic mate who helps build the race cars and their engines) works as a hydrualics fitter / engineer so I run most ideas by him...
AS I UNDERSTAND IT: in multigrade oil the 1st number indicates how well it flows when cold and the 2nd number indicates how well it flows when hot. The lower the numbers the thinner the oil.
15W-40 would be thinner than 20W-50 both when its cold and hot
15W-60 would be thinner than 20W-50 when cold and thicker than 20W-50 when hot
40W-70 would be extremely thick when cold and still thicker than 20W-50 or 15W-60 when hot
Thinner means lower oel pressure at idle. I don't like my oel pressure to drop below 1.0bar regardless of how hot or old the engine is so we (my mate BC and I) will try different multigrade oils until we find one which gives us an oil pressure we like at idle. We tend not to deviate too much from accepted norms, and don't run an oil with the first number less than 15, and the 2nd number greater than 60.
On the plus side 15W-40, 20W-50 and 25W-60 are amoung the least expensive oils around and we get good longevity out of our engines due to frequent oil changes - no buggered bearings in 20 years of engines make it clear in my mind the bearings are not starving for oil...
Just my 2c worth, - I'm not wishing to start any arguments.
