oscar
Ian, have a look at the Haynes manual, for some reason it's got a 6.9 suspension diagram even though not applicable to any of the models it covers, but in that same section is the recommended flow rate for the pump at a certain rpm. There's about 4 pages worth of info including some diagnostics and figures. I'm at work ATM and can't quote the figure and I'd be only guessing to try and remember it.
When I first changed a pump on my 350 I forgot to replace a copper seal that goes onto the outlet banjo fitting. I started the engine and only noticed my mistake when fresh hydro juice cascaded down the front of my motor and onto the floor. I lost over 500ml of oil in the time it took me to realise something was wrong and run to turn the engine off. So the flow was fairly constant.
EDIT, sorry dude, I posted just after you and didn't realise so I'm bumping your last couple of posts
Hey you know what I just did this test and noticed the output of the pump is not particularly volumous, or linear, more like its spitting fluid.
I don't know what I'm looking for but I presume a fairly decent volume (car was idling at 1400rpm cold idle), and in a more linear / less spitting type of delivery.
Anyone got a video on what the output should look like? I'm going to shoot one now but it will take till late late this afternoon for the results to show up on you tube.
