Front suspension that is....
The car's not undrivable, just very low at the front. When it used to do this I'd just drive and within a few km the front would pressurise and lift up.
The rear is fine - never sinks or does anything stupid. In fact has been perfect from day 1.
Recent stuff that has changed in the last 6 months:
1. Pressure warning light no longer illuminates ever... used to come on when I pulled out the height adjust knob, or when the front went down it would illuminate until the system had pressurised.
2. The annoying LH front corner hydro-fluid leak as mysteriously gone away... yes the tank is full of hydro fluid...
Des can you help me here?, I need to confirm what was changed during your ownership of the car... if memory serves its the 5 spheres, rear hydro struts, and control valve... Since I've had it I've changed the hydro-pump.
The front height control valve looks funky and the rod coming from it is not longer parallel to the ground L-R anymore.
I thought the hydro system on 6.9s, at least by 1979, was self-bleeding (just drive the car vigorously for a while)? Also when the suspension did pressurise at the front properly, all 5 spheres and 4 hydro-struts behaved as they should, giving the normal 6.9 magic-carpet type ride.
Help?
Ian.
Help?
Ian.
