Bentley Mulsanne - The Mighty New V8
More threads by Michel
Bentley’s new 6¾ litre, twin-turbocharged V8 engine blends state-of-the-art technology with a classic configuration that’s propelled Crewe’s finest cars for over 50 years.
Like the rest of the Mulsanne, every 505bhp V8 is hand-assembled and fully tested by Bentley’s technicians.
Right at the heart of Crewe’s new flagship Mulsanne is the company’s famous V8 engine which is renowned for delivering the Bentley ‘wave of torque’. The V8 engine, the same configuration of which has powered some of the company’s most iconic cars including the Arnage, Azure, Brooklands, the original Mulsanne, Turbo R and S2 Continental, has been completely re-engineered for the new Mulsanne.
The V8 configuration will strike a chord with aficionados, the 6¾ litre displacement having been the favoured option for many years. For the Mulsanne, however, the very latest technologies have been employed including two new control systems: cam phasing and variable displacement delivering even greater refinement as well as a 15 per cent improvement in emissions and fuel consumption.
The pioneering application of these new technologies in combination allows the Mulsanne’s engine management system to adjust the V8’s breathing for improved engine idle quality and torque delivery. However, by closing the valves of four of the eight cylinders, fuel economy is maximised when cruising.
All the major building blocks of the Mulsanne’s engine are new including the lightweight componentry such as pistons, connecting rods and forged crankshaft which reduce reciprocating mass and internal friction for improved engine response. These significant changes are complemented by the introduction of a new eight-speed automatic transmission offering virtually imperceptible gearshifts.
In total over 300 new or significantly re-engineered components have been created for the Mulsanne engine and the famed Bentley ‘wave of torque’ (1020Nm/752lb ft) is now delivered in full even earlier, at 1750rpm. This improvement in torque delivery from just above idle – as well as across the rev range – ensures that a mere tap of the throttle pedal will deliver phenomenal acceleration with 0-60mph achievable in just 5.1 seconds (0-100km/h in 5.3 seconds).
For Phil Cooper, Bentley’s senior production manager in the engine build workshop, the new V8 engine has provided an opportunity to introduce a range of new technologies whilst retaining the hand-built skills at which his team has long excelled. Phil explains:
“Our new V8 takes nearly 30 hours to build and we never release an engine to our colleagues in the main build hall until we are literally prepared to put our name to it.”
In the immaculately tidy V8 engine build area, where every set of craftsman’s tools are stored and labelled with the exact precision of a surgeon’s implements, the team use a combination of the high-tech and applied-by-hand skills to achieve the best results.
A state-of-the-art balancing machine ensures all the spinning components are rigorously tested (and if necessary rebalanced using tiny washers) and the level of accuracy achieved by this process ensures that when the engine is at idle there is not a hint of vibration. Alongside the use of the balancing machine, Bentley’s engine builders still fit each of the pistons into the V8 block by hand as well as the 16 individual ball-bearings which are inserted into the valve train.
Once assembled, every Mulsanne V8 is tested over an 80-minute cycle by the team. The ‘hot testing’ process tests the engine from idle through to maximum revs and the load on the engine is varied to simulate real-world driving conditions.
“Every element of the engine’s performance is analysed and recorded before it is sent through to the build hall,”Cooper explains.
Whilst the V8 engineering and engine-build teams have introduced a host of new technologies and are working with hundreds of new parts, one classic touch remains unchanged – a signed engine maker’s plate is still attached to every Crewe-built V8 to provide a reassuring symbol of quality, performance and reliability.
And they still use separate steel liners which - just may - still come adrift just like they always did - I hope they have improved that part of the design.
Porsche and Mercedes-Benz have been making Nikasil lined aluminium bores which can do 500,000 km for 30 years.
That aside - I would love one.
Because the RR/Bentley motor of the past 50 years is famous for developing loose liners.
Obviously BB earlier models were better designed/manufactured.
It's not only the V8 Bentley and Rolls Royce engines that develop loose liners - I have come across two Rover 3.5 lite engines that developed the same problem. It is quite difficult to diagnose the source when it happens as it is almost like a hydraulic lifter noise and it is necessary to remove head(s) to ascertain that a liner or sleeve has shifted. I had use of a Silver Cloud III for some nine months and it had a noisy lifter - see moving sleeve (I am sure that's what it was). The 'fixing' cost at the time was about $27K. I returned the car to the owner. Regards Styria
I am simply awaiting my test drive....:rolleyes:
This is a great thread in light of the comparison test between the S65 AMG Turbo versus the turbocharged Bentley Mulsanne. The design of the engine may date back to the fifties, but there have been a couple of improvements incorporated since then. Yes, as WGB says, those liners - will they, or could they, shift ? Nikasil coating seems the preferable, or perhaps, safer option. Regards Styria
WiSeGuYY
Cairo Egypt
Í AGREE with the PROFF . THE GHOST looks appealing more than the MULSSANE , but i will take either if i had the chance without any sour thoughts , but i think i will not ave any at my present life .
REGARDS
TAREK
motec 6.9 Bentley Mulsanne Speed Talking Torque 8
Styria S65 AMG versus Bentley Mulsanne Road Tests 12
Styria Mercedes S65 AMG vs. Bentley Mulsanne Turbo Road Tests 0
motec 6.9 New 1929 blower Bentley Talking Torque 2
c107 Bentley T2 and Turbo R Websites and Links 4
c107 The Derby Bentley Talking Torque 12
c107 Derby Bentley 4 1/4 Liter Talking Torque 5
Styria VW Phaeton and Bentley Websites and Links 3
motec 6.9 Bentley SUV Articles 0
motec 6.9 1953 Bentley R-type Continental Talking Torque 1
motec 6.9 1931 8 litre Bentley Boat Tail. Talking Torque 3
motec 6.9 1947 Bentley MarkVI Figoni Et Falaschi Talking Torque 8
motec 6.9 27 litre Bentley Talking Torque 4
motec 6.9 Rolls Royce and Bentley for Brian Talking Torque 6
motec 6.9 Bentley SUV Spotted Talking Torque 5
motec 6.9 1931 Bentley 8 litre sports Cab Talking Torque 2
Styria 2008 Bentley Brooklands Websites and Links 0
motec 6.9 Bentley Speed 6 W.A police cars Talking Torque 2
Styria Bentley flying spur Talking Torque 2
Styria Bentley GTC Convertible Road Tests 1
motec 6.9 27 litre Bentley for Michel and Brian Talking Torque 8
motec 6.9 8 litre Bentley Talking Torque 2
motec 6.9 6 1/2 Litre Bentley Talking Torque 0
motec 6.9 1947 Franay Bentley Talking Torque 0
motec 6.9 1937 gurney Nutting Bentley Talking Torque 1
motec 6.9 1968 Bentley Pininfarina coupe Talking Torque 10
motec 6.9 8 litre Bentley Talking Torque 0
motec 6.9 4 1/2 litre Bentley Talking Torque 10
motec 6.9 1937 Gurney Nutting bentley Talking Torque 9
Styria BENTLEY MX - 4.25 litre Derby Talking Torque 11
Des c123 vs Bentley Talking Torque 7
Des Bentley Boy Brian Talking Torque 7
