Transmissons move on
Gone are the days of 2nd gear start 4 speed Mercedes Trans, even the 1st gear start Valve Bodys in the 280SLs
Fast forward to Subaru's currant CVT. Going down hill yesterday, I found that it thinks for itself, (A. I.) downshifting on a feathered throttle, to effect engine braking. Selecting the manual over ride displayed the Gear number it had down shifted two.
I recall reading, that this transmission is best left to do its own thing. Forget the paddle shifts. These modern electronics amaze me.
Even as number 90 comes up at the end of this month I am never too old to learn !!
Sean you'd love the musical chairs they play with dual cab utes: many are made in Thailand, and the general consensus seems to be that 2 or more marques share each chassis: the Amarok and Ranger are the same car with different panels and engine options and iirc the Nissan Navara is related, the Mazda BT50 is really an Isuzu D-Max, and Mazda didn't even get to decide on the bodywork. But rewind a generation and the BT-50 was the Ranger, the Navara was the Mercedes X-Class, and all if them used Isuzu engines, because all of them were(/are?) made by Isuzu Thailand. Who used to also make the Holden Rodeo-cum-Colorado.
So the best selling car in Australia was a Ford, made by a GM subsidiary, and developed from a Holden.
But it's OK, because they made every one of its competitors, more or less, as well.
As for downshifting gearboxes on the overrun: my 2001 E46 BMW does that too, and it ain't no AI, just a ZF TCU ;)
Sean, a great observation on your part.
Most new transmissions are load sensing, plus grade sensing by a micro gyroscope.
Today's cars and trucks are fully controlled by the transmission, based on these inputs from your right foot, and feedback from the engine and exhaust management systems. We are now simply one input, throttle position.
Trucks (and I assume some cars) now have variable start gears. The Volvo trucks can use up to 6th start gears out of 12, based on payload and grade. It will select 6th if it is starting on a downhill grade, and down to first if needed on an uphill grade if fully loaded. If not loaded, even uphill it may start in 3rd or 4th, depending on engine variant and torque. Very smart, which equals great fuel efficiency.
That information is quite priceless, although one would think that major breakdowns could well test the knowledge of the Motor Vehicle Trade, and considerable costs are likely to hurt the hip pocket. I used to rebuild Borg Warner 35 and 65 boxes, and even Mercedes transmissions of the '60s and '70s were fairly straight forward. I am an avid reader of technical details on the Internet, and Auto Transmissions come in for quite a bit of criticism applying to a number of manufacturers. Nissan (CVT), Ford, GM are frequently mentioned, and it would also appear that the more gears you have, the more it costs for rebuilds. I have been interested for a little while now in a particular model (Toyota Crown Majesta) and it would seem that six Auto speed models are much cheaper to repair than the later model with the 8nspeed transmission. Just a bit of a ramble. Regards Styria
Complexity .... My simplistic trouble-free car was a 1929 Desoto two door Convertible. 6 cld side valve with hydraulic brakes. With a Crash Gear Box, a joy to drive. The Yanks were right all along!
Same car with a modern Carburetor and electronic Ign conversion. Re-signed Headers, and steel wheels to replace the wooden spokes....
Oh and it had an electric pusher fuel pump running on 12 volts. ..
